Fuel Pressure and timing
About the best spot for mine 38 vac off.......run it some like that and do a plug check...if Black or heavy Brown, I'd back off 2 Lbs....but I bet you'll be fine right there...If the plugs seem White or lean, than add a couple lbs..
38-40 is usually the sweet spot for most cars...
