Fuel pressure gauge
  • Thread starter Thread starter BlackVert
  • Start date Start date Apr 29, 2010
BlackVert
5,589
9
98
Bethesda, MD
Apr 29, 2010
  • Apr 29, 2010
you might ask, why is a guy who has a 1995 asking this question here and not in the 94/95 section ... well the answer is that my fuel rails are not 94/95 rails as the fuel pressure regulator has 3 bolts, not 2.
then again, it might not be from a fox either, but you guys can help determine that ...
how do you guys read your fuel pressure? my 1995 rails had a spot in the rail on the passenger side near the #1 injector that you could hook up a valve to. i don't see one on the rails on my motor.
please advise, thanks!
Mustang5L5
Mod Dude
Feb 18, 2001
43,371
18,119
224
Massachusetts
Apr 29, 2010
  • Apr 29, 2010
Same area... But a little further down.
Ypu mightvhave explorer rails
stykthyn
5,232
2,652
223
gainesville
Apr 30, 2010
  • Apr 30, 2010
explorer rails dont have a cross over at the front of the intake and the fuel lines attach at the rear of the motor.I have not seen or heard anyone use these rails due to the challenges involved in making them fit. Explorer rails(at least the ones I have seen) still have a schrader port so you can check fuel pressure.
BlackVert
5,589
9
98
Bethesda, MD
Apr 30, 2010
  • Apr 30, 2010
hmmmm, this one has a crossover at the front. i still have my old rails from the 5.0 that used to be in it. they have a spot where i could put a schrader valve. maybe i should modify them to fit the 351 ...
i'm not following you here ... are you talking about somewhere on one of the rails, or somewhere else?
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
J
Fuel Fuel Pressure Issue
  • justadude07
  • May 12, 2025
Fox 5.0 Mustang Tech May 12, 2025
justadude07
J
Fuel rail help
  • stang9150
  • Mar 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 5, 2026
stang9150
D
After Market fuel rails with Stock fuel lines
  • dropteeth
  • May 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 2, 2026
2000xp8
Trick Flow Series R to Box R Upper Intake Road Block
  • Habu135
  • Mar 31, 2026
  • 2 3 4
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 6, 2026
Habu135
