Fuel Pressure Issues
  • Thread starter Thread starter 1988WHTGT
  • Start date Start date Apr 12, 2009
1988WHTGT
270
Guyton, GA
Apr 12, 2009
  • Apr 12, 2009
I've been trying to get my car running good and noticed my fuel pressure is low. I have a Kirban AFPR, fuel pressure gauge on the rail and a 255 pump. My pressure at idle is sitting at about 10 psi. I tried adjusting at the regulator and nothing changes (vacuum line is off and plugged). Also, when I turn it off and go back to it a little while later the pressure gauge is reading 0. Is it my regulator?
1988WHTGT
270
Guyton, GA
Apr 13, 2009
  • Apr 13, 2009
Anybody? I put a new IAC on it yesterday (had a surging idle). Still only showing 10psi of fuel pressure. It was surging BAD this morning. Idles between 500 and 2200 RPM. My main thing right now is figuring out this fuel pressure thing though.
kpack5982
Yeah, it was pretty stiff, but eventually a buddy
Jul 13, 2005
325
Granger, IA
Apr 13, 2009
  • Apr 13, 2009
Could be a plugged fuel filter. I'd also check for vac leaks and see if you have a cracked line somewhere. That's all i can think right now.
50sn95blk
  • Jun 21, 2009
I have the same problem. running the same fuel setup but on a 95 5.0. Have you had any more luck on figuring it out?
D
Fuel Erratic Fuel Pressure 1985 GT
  • DienstXIV
  • Jan 14, 2026
Fox 5.0 Mustang Tech Jan 16, 2026
AeroCoupe
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
thread no longer needed
  • skidad
  • Oct 17, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
skidad
Fuel Bad regulator diaphragm?
  • JD1964
  • May 20, 2025
2K
Fox 5.0 Mustang Tech Jul 16, 2025
JD1964
C
98 gt fuel pressure issues
  • chasecollier1984
  • Jun 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 2, 2026
chasecollier1984
C
