Fuel Pressure Problem *Video Inside*
  • Thread starter Thread starter asecretfile
  • Start date Start date Jun 2, 2009
asecretfile
228
  • Jun 2, 2009
87 Mustang GT carbed Holley Blue electric pump
Video pretty much says it all. When the pressure goes from the preset 6.5psi down to 2 or 3, Im met with near silence from the pump. (and holley blue pumps are loud normally) Then it bumps back up to 6, pump makes normal sound, then back down to 2 or 3, near silence again. New fuel filter too
any ideas?
thanks
asecretfile
228
  • Jun 3, 2009
bump
BK_CAULEY
it's built for speed not longevity, woman
Dec 26, 2006
49
Thomasville, ga
Jun 3, 2009
  • Jun 3, 2009
theres alot on the table with this one man. what kind of regulator are you running? is it a single feed? return style? what kind of regulator are you using? do you have a fuel cell? a sumped tank? a stock tank with a home made pickup?
edit i watched the vid. have you checked the pressure at the pump? have you checked all of your grounds and hots to the pump to make sure nothing is getting hot and grounding out?
asecretfile
228
  • Jun 3, 2009
holley regulator, single feed going into double pumper carb, non return style, using stock tank with 85 style carbed pickup non sumped
I ran a red wire for the power to it. The ground is just the black off the pump goes right to the frame above it. Didnt run a separate ground just ran the pump black pigtail to the frame nearby
this only ever happens when the car/pump has been running for a while. And once it starts doing it it just keeps doing it until I turn the car/pump off and let it cool. After that it will runs fine until it heats up again.
Havent checked pressure at the pump, just at the regulator where I have the gauge at, but when the pressure drops, Im met with silence from the pump until it picks back up, and starts humming like normal again and back and forth
Sidenote: I felt the pump with my hand and it gets so hot I cannot hold my hand on it. Its not near the exhaust either
BK_CAULEY
Dec 26, 2006
49
Thomasville, ga
Jun 4, 2009
  • Jun 4, 2009
well it sounds like you have covered everything already. and it seems you know what your problem is.
asecretfile
228
  • Jun 4, 2009
I dont know actually, the ground wire, the pump bad maybe?
P
PJC Racing
199
  • Jun 5, 2009
I would say the pump. Holley blue's are known to be problematic.
asecretfile
228
  • Jun 5, 2009
Ive heard that as well. Unfortunately found that out after I had it a while. if it is bad, it is only 5 months old lol...I couldnt believe how hot it got...it was like I had just grabbed the tailpipe of a car that had been running for 2 hours
D
Fuel Erratic Fuel Pressure 1985 GT
  • DienstXIV
  • Jan 14, 2026
Fox 5.0 Mustang Tech Jan 16, 2026
AeroCoupe
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
I
1994 Cobra - Fuel Pressure Drops Revving at Idle
  • IconicSilverGT500
  • Apr 11, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Apr 24, 2026
Mcmahst
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
D
Engine 85 GT Backfires through Carb
  • DienstXIV
  • Oct 3, 2025
Fox 5.0 Mustang Tech Oct 7, 2025
85GTStangGuy
