  • 1994 - 1995 Specific Tech
Fuel pressure problem
  • Thread starter Thread starter fastas69
  • Start date Start date Apr 17, 2009
fastas69
  • Apr 17, 2009
I have a stock 95 mustang GT it's running like crap, it surges while your driving, has slow throttle response and if you floor it it will almost die then slowly pick up. I did a fuel pressure test, with key turned to on position the guage barley moved! Start the engine the gauge slowly moves to 34-35, pull the vacuum line and it's 44-45. So I replaced the fuel pump and filter and it didn't change a thing!! I checked the fuel lines for any kinks and such but did not see anything. Any ideas?
ProKiller
3,064
15
78
PA
Apr 17, 2009
  • Apr 17, 2009
did you clean your MAF? that fuel pressure seems fine to me for a stock car.
fastas69
  • Apr 17, 2009
No how do you go about doing that?
HISSIN50
34
129
Apr 17, 2009
  • Apr 17, 2009
Did you pull codes?
fastas69
  • Apr 17, 2009
HISSIN50 said:
Did you pull codes?
Yeah all im getting is 186, 172, 176 and 182 but I can't find anything on 182? So I don't know.
ProKiller
3,064
15
78
PA
Apr 17, 2009
  • Apr 17, 2009
i pull out the maf and take some rubbing alcohol and some q-tips and very gently wipe the metering wires. other people do it different ways.
fastas69
  • Apr 17, 2009
Bingo!!! That was it. Thanks. One more question, why does the fuel pressure barely register with the key in the on position? I was told it should jump up to 35-40 instantly?
Bosko5.0
1,067
longwood, FL
Apr 17, 2009
  • Apr 17, 2009
it should take like 2 seconds for it to reach 35 psi. Did you install the filter the right way?
I have a 255 pump and I idle at 30psi.
fastas69
  • Apr 17, 2009
I believe so from the tank to the side marked "IN" thats the way the old one came off, but the old one did the same thing though.
I
1994 Cobra - Fuel Pressure Drops Revving at Idle
  • IconicSilverGT500
  • Apr 11, 2026
1994 - 1995 Specific Tech Apr 24, 2026
Mcmahst
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
T
Help with a 95 5L crank no start
  • TheBubbaJoe
  • Nov 4, 2025
1994 - 1995 Specific Tech Nov 5, 2025
AeroCoupe
D
Fuel Erratic Fuel Pressure 1985 GT
  • DienstXIV
  • Jan 14, 2026
Fox 5.0 Mustang Tech Jan 16, 2026
AeroCoupe
