fuel pressure question
  • Thread starter Thread starter jasonc84
  • Start date Start date Oct 12, 2006
J
jasonc84
10
  • Oct 12, 2006
So about a week ago i changed the fuel pressure gauge because the one my notch came with wasn't working anymore. So new gauge read 60psi at idle so i asked around and found out that my acufab FPR could be broken. So i picked up a stock FPR and installed it today, started the car up and the pressure went right back to 60psi. So now with 2 fprs and 2 gauges (first one use to work) i'm still at 60psi. Ive also heard maybe there could be a blockage somewhere, looking for any other problems i could look for and also how to fix a blockage problem if that is it.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Oct 12, 2006
  • Oct 12, 2006
Mustangs use a shunt style regulator that bypasses the excess fuel back to the tank. If the return line is kinked or crimped, it will make the pressure increase.
J
jasonc84
10
  • Oct 12, 2006
ok so checking the return line seems like the easiest place to start thanks for the response. Also any other sugestions are welcome so i can have more than one thing to check tomorrow.
J
jasonc84
10
  • Oct 13, 2006
any other potential problems that could cause this??
JChalfan
551
Bellevue, WA
Oct 13, 2006
  • Oct 13, 2006
I agree with jrichker about the kinked return line. I had that problem on one of my 5.0's after an engine swap. The rubber part of the return line got snagged on something and kinked, and my fuel pressure was way too high.
How's the car running/driving? I would think that it wouldn't run really great with the FP at 60psi. It should at least be running really rich.
Jeff
J
jasonc84
10
  • Oct 13, 2006
it is def running really rich, you can smell unburnt fuel and it wont pass emisions, the idle is pretty good though surges every now and then but its pretty steady, im a mustang noob so where is the return line, do i need to jack the car up to check it??
JChalfan
551
Bellevue, WA
Oct 13, 2006
  • Oct 13, 2006
There should be two lines running from the fuel rails, one feed and one return. The return should be the smaller of the two. Steel lines run from the back of the car to the front, then there is a pretty short rubber section, and then metal lines again going into the fuel rail. The rubber section will be on the passenger side, just follow the metal lines from the fuel rail. You shouldn't have to jack it up to check it, I don't remember for sure how much you can see from the top.
Jeff
Flavadave4
1,044
21
49
Utica, NY
Oct 13, 2006
  • Oct 13, 2006
I think those guys have the right idea, is it possible you are that far out of adjustment?
J
jasonc84
10
  • Oct 13, 2006
im not sure how it could be that far out of adjustment with a stock FPR in there and stock fuel pump, stock injerctors etc. The whole fuel system is stock so doesn't really make sense to me.
Flavadave4
1,044
21
49
Utica, NY
Oct 13, 2006
#10
  • Oct 13, 2006
  • #10
Sounds like something is blocking the return line.
J
jasonc84
10
#11
  • Oct 13, 2006
  • #11
hopefully its just a kink somewhere so i don't have to replace the return line.
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
D
Fuel Erratic Fuel Pressure 1985 GT
  • DienstXIV
  • Jan 14, 2026
Fox 5.0 Mustang Tech Jan 16, 2026
AeroCoupe
thread no longer needed
  • skidad
  • Oct 17, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
skidad
C
98 gt fuel pressure issues
  • chasecollier1984
  • Jun 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 2, 2026
chasecollier1984
C
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
