Fuel pressure reading unstable
  • Thread starter Thread starter DMAN302
  • Start date Start date Apr 10, 2004
DMAN302
My mom says thanks for the pearl necklace.
Nov 8, 2003
2,120
windsor, Canada
Apr 10, 2004
  • Apr 10, 2004
Hey wondering if someone can help me out with some info here.
Yesterday I had my bad boy out for a run when I noticed my fuel pressure gauge was reading 37-39 lbs while driving light or heavy or at a stop just idleing, then later ( about 5-10 minutes later)the pressure would drop back to low near 30 at idle???? the Idle is strong and steady so why would I have 38-39 psi at idle with engine at normal operating temp? Fuel gauge is a phantom autometer, and I will note that when I pull the vac line of the intake from my stock fuel regulator the Idle will raise up and the pressure on the gauge reads a solid 39 psi vac off. Is it normal to pull 38-39psi pressure just sitting there at idle..or is my regulator acting up?
85 Coupe 5.0
817
Kansas
Apr 10, 2004
  • Apr 10, 2004
The pressure should jump about 5 to 9 LBS when you unplug the regulator. Idle Fuel pressure should be around 35 or so? maybe someone can chime in with a spec. But, reguardless, it should go down about 5 to 9 LBS when you apply vacuum to the regulator and go back up when you take it off. Since you have an in-car guage, it should jump up under acceleration and go back down upon letting up on the gas pedel.
DMAN302
Nov 8, 2003
2,120
windsor, Canada
Apr 10, 2004
  • Apr 10, 2004
Yes it should but the pressure is hanging high wether I'm at idle or under acceleration I find the gauge will fall back to 30-35# most often, but sitting at a light 38-39# seems too high..like I said vacume off the idle will come up a bit and the needle will jump to the proper pressure of 39 which is factory spec. Question is about my reading at idle with vac on..I know what vac off should do. Thanks for the imput though I do apreciate it.
85 Coupe 5.0
817
Kansas
Apr 10, 2004
  • Apr 10, 2004
ok, so stock is 39 PSI, under WOT conditions. Sooooo, at idle you should see 32 to 35 PSI. As long as you don't have an adjustable regulator. Is there any fuel coming out from where the vacuum line goes into the regulator? Sounds to me like the regulator is on it's way out, but it's hard to tell without a little more testing.
D
Fuel Erratic Fuel Pressure 1985 GT
  • DienstXIV
  • Jan 14, 2026
Fox 5.0 Mustang Tech Jan 16, 2026
AeroCoupe
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
C
03 Cobra Low Fuel Pressure
  • CTsnake_03
  • Mar 17, 2026
1996 - 2004 SN95 Mustang -General/Talk- Mar 24, 2026
CTsnake_03
C
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
C
  • Locked
Fuel pressure too high
  • Canadianfox
  • Jul 4, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 11, 2025
