Hey wondering if someone can help me out with some info here.
Yesterday I had my bad boy out for a run when I noticed my fuel pressure gauge was reading 37-39 lbs while driving light or heavy or at a stop just idleing, then later ( about 5-10 minutes later)the pressure would drop back to low near 30 at idle???? the Idle is strong and steady so why would I have 38-39 psi at idle with engine at normal operating temp? Fuel gauge is a phantom autometer, and I will note that when I pull the vac line of the intake from my stock fuel regulator the Idle will raise up and the pressure on the gauge reads a solid 39 psi vac off. Is it normal to pull 38-39psi pressure just sitting there at idle..or is my regulator acting up?
