Fuel pressure set right
LaserSVT
3,548
233
Finnaly got my fuel pressure rail adaptor today. When I set the pressure do I do it with the vaccume line on or off. I set it to 40psi with it off and when I hook the line on it drops to 36, and fluxuates as I rev it. Do I set it like that or leave it connected and set it at my desired pressure with the vac line on?:shrug:
Set the fuel pressure when the vacuum line is off. It's supposed to fluctuate...well, it's supposed to go up when you rev it, if it goes down you have a problem with the fuel delivery.
Thanks, seems to work just fine. And ya the pressure goes up with throttle, not down. I set it @ 40psi and under WOT it will go as high as 41psi but no higher.
