fuel pressure too high
  • Thread starter Thread starter importsmokinGT
  • Start date Start date Oct 30, 2010
I
importsmokinGT
20
Jax, Fl
Oct 30, 2010
  • Oct 30, 2010
I'm trying to get this car started but found a major fuel problem while checking for leaks. fuel was pouring out of the carb a few seconds after the pump turned on. kept messing with the carb (needles,float, o-rings) and got the leakage to slow enough to check fp. it was 12. geez! got it adjusted down to 9.5 before the adjustment screw came out. I'm wondering if this is a regulator problem or maybe a fuel line problem. the goods: fox, carb conversion. sumped tank to an aeromotive 11106 in-line pump, #8 all the way up to the reg, aeromotive 13301 bypass style. #6 x2 to the two carb inlets and a #6 return back to the stock fuel pump assembly. no pump in tank, just using it to return. any ideas? the reg is supposed to get down to 3psi so i'm a good 6.5 over . can the fuel line i'm running cause that much pressure increase?
thanks for any help !
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Oct 30, 2010
  • Oct 30, 2010
I am working on the dangerous assumption that you are not using a EFI fuel pump of any type or description. Carb pumps should be able to keep the fuel pressure down low enough so that getting it adjusted would not be a problem. The only fuel line that can increase the pressure in a return system is the return line. The return line would have to be kinked, too small or obstructed in some fashion for it to cause the pressure to be too high and not be regulated down to the 3-6 PSI you need.
I
importsmokinGT
20
Jax, Fl
Oct 31, 2010
  • Oct 31, 2010
actually the aeromotive pump is for carb or efi. their website does not give flow rate but says up to 700hp efi, or 900hp n/a carb. i'm also using the recommended aeromotive bypass regulator. they do recommend at least #8 return and I have #6 going back. it just seemed like a huge pressure increase for it to be too small of a return line. on the other hand, the car is not yet running and that is the only place for the fuel to go, besides pouring out of the carb.
D
Fuel Erratic Fuel Pressure 1985 GT
  • DienstXIV
  • Jan 14, 2026
Fox 5.0 Mustang Tech Jan 16, 2026
AeroCoupe
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
A
Resolved Fuel pressure high at 52 new FPR same thing
  • afjLX
  • Dec 28, 2024
  • 3 4 5
5K
Fox 5.0 Mustang Tech Jan 11, 2025
AeroCoupe
I
1994 Cobra - Fuel Pressure Drops Revving at Idle
  • IconicSilverGT500
  • Apr 11, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Apr 24, 2026
Mcmahst
D
Fuel 1985 GT Fuel Line Diagram
  • DienstXIV
  • Apr 17, 2025
2K
Fox 5.0 Mustang Tech Jul 12, 2025
DienstXIV
D
