Fuel Pressure what PSI?
  • Thread starter Thread starter soontobefastfox
  • Start date Start date Jun 15, 2007
soontobefastfox
275
Troy, Michigan
Jun 15, 2007
  • Jun 15, 2007
I am going to fire up my stang next week after almost 2 years of working on it!
I have a question what PSI should I set my adjustable fuel pressure regulator?
I think stock is like 36-38ish? Should I set it to stock settings or bump it up because its been modified alot.
331, vic jr heads, xfi comp cam, 42 lbs injectors, aeromotive fuel kit with custom sumped stock tank, etc.
It'll be running N/A for about a year or 2, saving up for the procharger...
Thanks in advance!
cobradvm
245
Woodinville, WA
Jun 15, 2007
  • Jun 15, 2007
39-40 is a good place to start. Those are big injectors for a 331 - may have some idling issues - have you thought about any engine management systems to help tune it?
soontobefastfox
275
Troy, Michigan
Jun 15, 2007
  • Jun 15, 2007
Why would I have idling issues? It should have around 400 at the flywheel and as I said down the road it will have a procharger.
Ok I'll start with 39-40 psi. I am getting a SCT chip and having it dyno tuned. I just want to fire it up and make sure it runs before I take it to the tuner.
Foxfan88
My Grandpa has great wood.
Sep 13, 2004
2,487
Miami, Ok
Jun 15, 2007
  • Jun 15, 2007
around 40 psi to get it moving, tinker around on the dyno to find what the optimum psi level is
D
Fuel Erratic Fuel Pressure 1985 GT
  • DienstXIV
  • Jan 14, 2026
Fox 5.0 Mustang Tech Jan 16, 2026
AeroCoupe
C
98 gt fuel pressure issues
  • chasecollier1984
  • Jun 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 2, 2026
chasecollier1984
C
  • dan50
  • Jul 18, 2026
dan50
Forced Induction Total Timing under boost
  • Dontknowchit
  • Aug 27, 2025
Fox 5.0 Mustang Tech Aug 28, 2025
Dontknowchit
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
