Good question.
I think he means in general. You can basically do two things if you want to work on the fuel system but don't want to deal with pressure:
1 - Let the car sit over night, it will be gone by then
2 - While the car is idling, kill it by triggering the inertia switch in the trunk. This is will cut off the fuel pump and there will be no fuel pressure. The car will stall out and a CE light will come on, but, after you are done and enable the switch and start it up, it should go off. This is how I always do my fuel system work.
Adam
