Fuel pressure
Itkix
116
I just installed a fuel pressure guage and it only shows I have 11#, I just bought a Summitt brand ranges from 0-100, I have a BBk fuel pump 155, I see two fuel lines going into the injectors does it matter the one I used. Thanks
I'm guessing the shrader valve is in the fuel line that looks like a valve stem when you take the cap off, if so my guage will not screw into that (to big), I have the guage on the opposite line of the shrader, could that be a problem.
That may be the return line. The schrader valve into the fuel rail is a 1/16 NPT thread. Your gauge is probably a 1/8 NPT. All you need is an adapter.
