Fuel Problem I Think
lgbnaf7
61
Tacoma Wa
I have been having this car for 3 months but Sunday was my first time really driving it. When I started it my battery seemed kind of weak but it kicked over. Well Sunday I was driving along and pulled up in front of a store then the car died. I figured the battery died. I got a jump start from a guy and the car started right up then 1 minute later it died again. As long as I had the jumper cables on the car it would start but would not stay running. Just so happen in the parking lot of the store was a Firestone Tire Center. I took the car there and my battery was dead. I replaced the battery and the car will start but idles really rough. I thought it was the fuel pump but it kicks on and primes when I turn the switch. I change the fuel filter and it seems to still idle a little rough. Any Suggestions on what else to check?
See the sticky "Help me create the Surging Idle Checklist" at the top of the forum for help with your idle problems. The first post has all the updated answers.
Dump the codes and see what the computer says is wrong…
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
OR
See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Walmart.
Or for a nicer scanner see http://www.midwayautosupply.com/detailedproductdescription.asp?3829 – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $35.
