Fuel problem...need help quick.
WhiteThunder
52
Ok...every know and then my mustang will decide that it doesn't want to get any fuel pressure, due to the fact that my pump is not turning on. It's done it to me...I'd say about 4 -5 times since i got it almost a year ago. I just had the pump replaced with a 255 (got it back yesterday) and the mechanic said all the connectors are fine and the wiring looks good. Well today I got stranded because it wouldn't start a good 40 miles from home. I finally got it to start and drove it home...I thought that would be the end of that until I got home and it died in my driveway and wouldn't start.I pressed a button on a box in my trunk 3 times and got in the ar and it fired up. Any ideas? What is the box I'm pressing? Help of course is greatly appreciated.
okay man you have a couple choices this happen to me and it was my computer relay but most causes like this are the fuel pump relay witch is under the driversid seat, replace that befor anthing else. Oh yea and that little box in the trunk with the button is called a inersha switch it is there in case of accident it defusses the fuel pump and the button resets it, You should also check the two wires going into that. hope this helps
I would pull codes. Then when it wont start, put a FP gauge on the Schrader valve. If pressure is good, check spark. If good, and you think it is fuel pressure electronics related (this appears as a code 95 and 96 BTW), when it wont start, use a DMM on the 4 terminals on the FP relay under the seat. Post the results of what you have key off, key on and pump priming and key on and pump not priming.
Good luck.
I've replaced the fp relay twice (once it didn't need it) when it does this my fuel pressure gauge reads 0 instead of the 35 it usually reads. It also gets good spark I checked that first thing. I've already pulled the codes and none come back ...so I'm really stuck as to this problem, I'm afraid to drive far because I don't want to get stranded. I'm going to check the two wires on the inertia switch in the morning..and were is the computer module? how easy is it to check that?
check the 2 grounds to the computer and th EEC relay... coming off the neg battery cable u should have an extra wire goes into a (its black 1 wire looks like a bullet)connector and then to a ground on the fender apron on driver side... clean that connector and put electric grease in it sometimes it can corode.. then pull pass kick panel off and make sure the ground wire on the body is tight i scraped alil paint off on mine. the EEC relay is just above the computer its easy to get too if u take off the glove box door and the pass kick panel
Just because the FP relay was replaced does not mean that it is getting the proper signals. That is why testing each terminal when it acts up is key IMHO. That FP relay connector is like a 4 way stop and knowing what you are missing tells you what direction to go.
The only reason I would pull the puter is if the ground strap for the FP relay went south. If that pulsed ground is fine during testing, that is not the cause.
Good luck.
Fuel Pump Troubleshooting for 86-90 Mustangs
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 5-20 seconds and shut off. To trick the fuel pump into running, find the ECC test connector and jump the connector in the lower RH corner to ground. See http://www.mustangworks.com/article...c-iv_codes.html for a description of the test connector. If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. A tire pressure gauge can also be used if you have one - look for 37-40 PSI. Beware of fire hazard when you do this.
A.) Tripped inertia switch – press reset button on the inertia switch. The hatch cars hide it under the plastic trim covering the driver's side taillight. Use the voltmeter or test light to make sure you have power to both sides of the switch
B.) Fuel pump power relay – located under the driver’s seat in most stangs built before 92. On 92 and later model cars it is located below the Mass Air Flow meter.
C.) Clogged fuel filter
D.) Failed fuel pump
E.) Blown fuse link in wiring harness.
F.) Fuel pressure regulator failed. Remove vacuum line from regulator and inspect for fuel escaping while pump is running.
The electrical circuit for the fuel pump has two paths, a control path and a power path.
The control path consists of the inertia switch, the computer, and the fuel pump relay coil. It turns the fuel pump relay on or off under computer control. The switched power (red wire) from the ECC relay goes to the inertia switch (red/black wire) then from the inertia switch to the relay coil and then from the relay coil to the computer (tan/ Lt green wire). The computer provides the ground path to complete the circuit. This ground causes the relay coil to energize and close the contacts for the power path. Keep in mind that you can have voltage to all the right places, but the computer must provide a ground. If there is no ground, the relay will not close the power contacts.
The power path picks up from a fuse link near the starter relay. Fuse links are like fuses, except they are pieces of wire and are made right into the wiring harness. The feed wire from the fuse link (orange/ light blue wire) goes to the fuel pump relay contacts. When the contacts close because the relay energizes, the power flows through the contacts to the fuel pump (light pink/black wire). The fuel pump has a black wire that supplies the ground to complete the circuit.
Remember that the computer does not source any power to actuators, relays or injectors, but provides the ground necessary to complete the circuit. That means one side of the circuit will always be hot, and the other side will go to ground or below 1 volt as the computer switches on that circuit.
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host)
http://www.veryuseful.com/mustang/t...witchWiring.gif
http://www.veryuseful.com/mustang/t...inks-ign-ac.gif
http://www.veryuseful.com/mustang/t...91eecPinout.gif
Now that you have the theory of how it works, it’s time to go digging.
Look for 12 volts at the Orange/Lt. Blue wire (power source for fuel pump relay). No voltage or low voltage, bad fuse link, bad wiring, bad ignition switch or ignition switch wiring or connections. There is a mystery connector somewhere under the driver’s side kick panel, between the fuel pump relay and the fuse link.
Turn on the key and jumper the fuel pump test connector to ground as previously described. Look for 12 volts at the Light Pink/Black wire (relay controlled power for the fuel pump). No voltage there means that the relay has failed, or there is a broken wire in the relay control circuit.
Check the Red/black wire, it should have 12 volts. No 12 volts there, either the inertia switch is open or has no power to it. Check both sides of the inertia switch: there should be power on the Red wire and Red/Black wire. Power on the Red wire and not on the Red/Black wire means the inertia switch is open.
The Tan/Lt Green wire provides a ground path for the relay power. With the test connector jumpered to ground, there should be less than .75 volts. Use a test lamp with one side connected to battery power and the other side to the Tan/Lt Green wire. The test light should glow brightly. No glow and you have a broken wire or bad connection between the test connector and the relay. To test the wiring from the computer, remove the passenger side kick panel and disconnect the computer connector. It has a 10 MM bolt that holds it in place. With the test lamp connected to power, jumper pin 22 to ground and the test lamp should glow. No glow and the wiring between the computer and the fuel pump relay is bad.
If all of the checks have worked OK to this point, then the computer is bad. The computers are very reliable and not prone to failure unless there has been significant electrical trauma to the car. Things like lightning strikes and putting the battery in backwards or connecting jumper cables backwards are about the only thing that kills the computer.
So it is possible that my inertia switch going out is the cause of my problem? It seems like it shouldn't be to hard to replace...once I get my hands on one...my mechanic said that they're probably dealer only parts. I'm gonna replace it anyway just in case. Any thoughts?
White Thunder, it is cheaper to go through JR's checklist or follow the advice for troubleshooting on this thread than to guess and toss money at parts. Literally 10 seconds spent with a DMM can tell you if the inertia switch is likely (remember that 4 way stop part of one of my posts - that is what we are talking about here).
Just my two cents. good luck.
I just thought that since the inertia switch was starting to look pretty bad I'd go ahead and replace it and hope that that was the problem because the car is running now and is showing no problems and I don't want to wait for it to break down again.
If it looks faulty, I can see the point of replacing it now. Intermittant issues are hard to track down, but it is nice to know that you isolated and replaced the faulty part.
The switch should not be too expensive. If the dealer wants a lot of $$, try resto houses like LRS ( www.50resto.com ). Good luck.
