90 GT 5 speed.
Well I decided to replace my 24# injectors since I has some that were sticking open. I planned on putting nitrous on the car later so I upgraded to 30# injectors and a 80mm MAF. I thought I would be running really rich but its the exact opposite. The car wont pull in the higher RPM's and it will detonate sometimes which leads me to believe that I'm not getting enough fuel. Fuel pressure is set at 40psi with the vacuum line off. Fuel pressure goes down when you press the throttle. That doesnt seem normal. Anybody know what the problem could be?
