Fuel Problem?
  • Thread starter Thread starter black92coupe
  • Start date Start date Sep 20, 2007
black92coupe
  • Sep 20, 2007
recently ive been having a weird problem with my car, its a 5.0 speed density car
it revs freely when its out of gear but sometimes when you pin it the car bogs for a sec and then all the power comes back after a few slow rpms. sometimes it runs perfectly fine.
other times it bogs n then starts to make popping sounds in the intake i belive, and the whole car starts shaking and u can barely move, ive heard the exact same popping sound when i ran out of gas.
it has these problems weather i have a quarter tank or if its full.
any help is appreciated
troyGT03
278
too close to memphis,tn
Sep 20, 2007
  • Sep 20, 2007
as a speed density guy...check the codes. we dont have a check engine light. http://www.troublecodes.net/Ford/ try this first.
F
Fox8950
247
Sep 20, 2007
  • Sep 20, 2007
Yeah of course check codes first like troy said Have you checked out fuel pressure and is there any chance your timing is off?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Sep 21, 2007
  • Sep 21, 2007
Some help with dumping the codes...
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
See http://www.troublecodes.net/Ford/
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see http://www.midwayautosupply.com/pc-7208-90-equus-digital-ford-code-reader-3145.aspx – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
I
98 Mustang GT dying
  • ItsMason
  • May 14, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 25, 2026
lenzgt
L
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
L
Help with 1986 GT 5 Speed Please
  • Lcasada1999
  • Mar 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
I
1994 Cobra - Fuel Pressure Drops Revving at Idle
  • IconicSilverGT500
  • Apr 11, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Apr 24, 2026
Mcmahst
F
Fox Fuel or spark issues?
  • Frank cortez
  • Apr 3, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 4, 2025
AeroCoupe
