FUEL PROBLEM!!!
TurboGN87
10
I have an 89 5 Oh and at wide open throttle the fuel pressure drops about 10 lb it also drops to 0 as soon as I shut the car off. Ive had 3 different fuel reg. , 2 different fuel pumps.
What Ive checked..
I used 2 different fuel gauges and had the same reading.
I checked the injectors and their not leaking.
I blocked off the return line at the fuel rail after the reg. and it held pressure for 3 hours but as soon as I hooked the return line back up it drops pressure.
What can be going on here?
The only thing that I can think of is maybe the little rubber check valve or whatever it is at the end of the return line in the tank might have something to do with it.
any suggestions would be appreciated...
Thanks
Checked all lines on pump and everything is tight.
Does anyone know the correct way to check voltage at the pump?
I just want to be sure the power is there at wide open throttle..
look under the rear bumper by the gas tank the fuel pump harness should be there, disconnect it or tap into it and read the power wire with a voltmeter, I think the one wire is the fuel pump ground too so I would use that ground for the most accurate reading.
I have found the problem with my car and it ended up being a vacuum leak...
I run the NoS dry system and I checked the vacuum at the vacuum port and
then I checked it at the Fuel regulator and the regulator had almost no vacuum.
so I disconnected the Nitrous system from the regulator and now the fuel pressure don`t drop at wide open throttle.
My car still drops pressure when I shut it off but after calling around I hear that
some cars will and some car don`t drop pressure.
I was more worried about WOT..
