Fuel problem
Was driving last Friday and pulled away from a stop sign when the engine started chugging and bogged down (ran fine up to this point). Pulled over and put it in park, started idling ok again but when I turned around to head back home it started chugging again, no matter how much gas I gave it it wanted to die. Luckily I was only a few blocks from home when it finally died and I couldn't get it to start again.
Basically it looks like the carb is not getting any fuel at all. With the choke wide open and manually working the throttle, I don't see any fuel spraying out of the jets. I was able to spray starter fluid in there and got it to start off that but dies when it burns all the fluid.
The fuel pump is new, and I have a new fuel filter between the pump and the carb. My fuel gauge isn't working so I double checked the tank with a string and nut to make sure I have gas in the tank (high tech I know!).
Car has been running great lately, no signs of anything going wrong.
Would it be normal if the fuel filter is clogged to just completely stop the flow of fuel? I know there is a little bit of crud in the gas tank, when I pulled the sender last year there was a little bit of junk that drained out but not bad.
What do you guys think? Fuel filter? Fuel pump? Something else entirely? If it's the filter should I think about replacing the gas tank since it clogged up a new filter after maybe 100 miles of driving?
yes, the filter can clog completely and kill the engine. It is worth it to clean out the tank. Mine was full of newspapers, rocks, and papertowels when I purhcased the car 6 years ago. Drain the tank clean it out and blow your fileters out.
start with the easy stuff;
give the float bowl a rap with a screwdriver near the fuel inlet as you might have a stuck float.
next replace the fuel filter, it probably needs it anyway.
third check fuel pump output before the fuel filter, it is still possible to have a bad pump diaphram.
fourth check your fuel lines for proximity to high heat sources like exhaust pipes. you may be developing a vapor lock problem.
fifth check your fuel lines for clogging as you may have one either partially of fully clogged.
+1 on that,
one more thing tho, if that still weilds nothing, pull off the pump and look at your fuel pump excentric, after i put my cam in, mine came loose and I had the same problem you did, no fuel whatsoever.
good luck!
-john
