Fuel Problem
  • Thread starter Thread starter dlawler2
  • Start date Start date Aug 20, 2008
First Prev 2 of 2
D
dlawler2
12
#21
  • Aug 23, 2008
  • #21
nm guys got it... Thanks for everything!
HISSIN50
34
129
Aug 23, 2008
#22
  • Aug 23, 2008
  • #22
If you post the solution to the issue, it helps people in the future when they search.
D
dlawler2
12
#23
  • Aug 23, 2008
  • #23
I'm pretty sure my problem was the battery (car's back to not starting now). But what was happening was the fuel pump was never getting the initial 12V it needed to prime. After a little bit of a charge it would get 12 for around 5 seconds, just enough to build up pressure to start. Once it got started it ran fine and I drove it around for 15 minutes or so. The battery that's in there is charging now and drawing a ton of amps so I'm pretty sure it's nearly dead. I'll probably end up swapping it out tomorrow and I'm hoping that should do the trick.
First Prev 2 of 2
D
1989 mustang 5.0 crank no start
  • Darkstang302
  • Tuesday at 3:24 PM
Fox 5.0 Mustang Tech Yesterday at 8:36 PM
AeroCoupe
  • Mindseye007
  • Aug 16, 2026
Mindseye007
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
Engine Fuel not pumping
  • Creomod
  • Apr 13, 2026
  • 2 3
2K
Fox 5.0 Mustang Tech Jul 22, 2026
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
