Engine Fuel not pumping
Before you do that. Pull the distributor and then connect the wiring back up. Turn the key to "run" and then go back under the hood and spin the distributor gear by hand. You should hear the injectors fire and if you do the PIP is good.
Reactions: Creomod
Guessing you got it stabbed out of time. Probably best to just start over by putting the motor at TDC, stab the dizzy and the rotor should point at the #1 cylinder post on the cap with the distributor fully installed. I install the cap and just make a mark on the adapter (what the cap connects to) where the #1 cylinder post is.
You have to be on the compression stroke or it will be 180 out.
Reactions: DadLife0724
O god I did now I’m getting codes 91 31 41 I bought a pip sensor yesterday and the box looked messed up so I was already sus bout i. I stalled it so I literally going to swap it again in just a few
So 91 and 41 are O2's reading lean:
Code 41 is a RH side sensor, as viewed from the driver's seat
Code 91 is the LH side sensor, as viewed from the driver's seat
Do you still have the smog pump and crossover tube?
Reactions: Creomod
Guys I’m having issues I changed the distributor yesterday brand new lmk m,new fuel relay,fuel pump the ignition switch the fuel regulator car is sputtering not running right code 85,31 I don’t think the egr would cause this at all I have a extra one I’ll swap it in just a few minutes. Can it be a bad fuel injector? A leaking fuel injector . I’ve spent money already swapping out all the fuel components and now fuel injectors . Can a leaking injector cause this? How can I find a leaky injector ?
The codes are all over the place. Are you sure the ECU is good?
Only way I know to check a for a leaking injector is to read the plugs. If one of them is wet and smells like gas then there you go.
You replaced the distributor? Most new ones are absolute :poo:. My car ran like crap and stalled/shut off,I replaced three distributors from O'Reilly s.
Just maybe that's your problemo?
Reactions: Creomod
I used a white paint pen on the Motorsport balancer in the T-Bird as those marks were very hard to read. The ones on the Fluidampr balancer in the Coupe were already white so very visible.
Reactions: Creomod
I read where the crossover tube would get plugged and would cause these codes so wanted to rule that out. If you can scrounge up a known good distributor you could try that but I am still leaning towards a bad ECU.
Reactions: Creomod
Now out of no where the car started . Fuel going to gauge.
Don't rule out corrected connections of brittle wiring as well here.
I don't think anyone has said it yet, but a couple years ago I had similar fuel pump issues where it would just quit out of nowhere. I did the same fuel pump relay replacement, jumpered the pump on full time to test and everything would work. I would put the relay back in and all good for a while. Then out of the blue it would quit again.
For me, it turned out to be the connector in the driver side kick panel area. The power wire for the relay goes through this connector. What I found was the female pins had opened up and were not making good consistent contact with the male pin on the other side of the connector. A simple tap of your foot against the kick panel could cause the fuel pump to lose power - not a fault with the relay, just no power to the relay. To fix it I used a small precision screw driver to bend the two halves of the female pins inward and cleaned both sides of the connector. I haven't had an issue since.
I had to do the same thing with the pins on my power window switches as these were intermittent at times too. Worked great there as well.
