Fuel pump and nitrous question
  • Thread starter Thread starter DMAN302
  • Start date Start date May 23, 2006
DMAN302
My mom says thanks for the pearl necklace.
Nov 8, 2003
2,120
windsor, Canada
May 23, 2006
  • May 23, 2006
Presently I'm running a 190 pump with 24 pound injectors on my 88, the motor sports Eddy RPM heads/comp XE270 cam and a forged shortblock. Question is will the fuel system support a 75 shot (nitrous works injected by plate between TB and intake)with the current components? or do I need to look at any possible upgrades for fuel system components?
DMAN302
Nov 8, 2003
2,120
windsor, Canada
May 23, 2006
  • May 23, 2006
Should add while doing the bump is the MAX shot I will be running will be the 75.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
May 23, 2006
  • May 23, 2006
The following examples are only for naturally aspirated engines. HP is measured at the flywheel in all of them
Injector HP ratings: divide flow rating by.5 and multiply the result by the number of injectors. This uses a 100% duty cycle.
Example:
19/.5 = 38, 38 x 8 = 304
24/.5 = 48, 48 x 8 = 384
30/.5 = 60, 60 x 8 = 480
The preferred duty cycle is about 85% maximum, so for a safety factor multiply the final figure times .85 (cheat on the math and use .588 instead of .5 and you don’t have to multiply the end result by.85)
Remember that the above ratings are at 39 PSI. Increasing the pressure will effectively increase the flow rating. Example: a 19 lb injector will flow 24 lbs at 63 PSI, and a 24 lb injector will flow 30 lbs at 63 PSI.
A 190 LPH fuel pump will support 500 flywheel HP.
DMAN302
Nov 8, 2003
2,120
windsor, Canada
May 23, 2006
  • May 23, 2006
So based on the assumption that my current combination of parts is under 350 Flywheel and that best case scenario 75 shot should provide 60-65 HP I SHOULD find myself fairly safe at 40-42 PSI...correct?
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
D
Fuel pump upgrade
  • dkrupp79
  • Jul 7, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 10, 2025
Scrapla347
J
Forced Induction Turbo SBF Fuel system RECOMMENDATION
  • Jschallitz
  • Jul 31, 2024
2K
Fox 5.0 Mustang Tech Aug 2, 2024
Monkeybutt2000
M
L
Whats a safe limits to take this engine to?
  • LCATGA
  • Sep 3, 2024
2005 - 2014 S-197 Mustang -General/Talk- Sep 5, 2024
89ripper
SOLD SOLD!!!! 1993 Notchback Roadracer For Sale. She's a beast!
  • Boydster
  • Apr 25, 2025
Fox Body Mustangs For Sale (1979-93) Apr 25, 2025
Boydster
