Fuel Pump BS!!!!!!!!!!
Guero
2,148
Ok so i drop the tank remove the fuel pump. Then i realize theres no way i can make the 255 fit, its to thin, and will just fall, is there like a another thing i need to buy? plus if a change it out how will the gauge work for the gas?
I realy dont know never saw an intank 255, just in-line 255 setups.
My 190 was alittle longer (or was it shorter) than the stocker, I just bent the bracket to fit, but make sure the pickup is in the same depth/location. I remember it took alittle doing but nothing that stands out really.
when you take out the the ring on top of the fule pump, and take out the thing with the rubber piece, thats not it is it? i think i looked at that instaed god dam now i have to lift it up again
oh i see what i did wrong. i lloked at the thing that tells you how much gas is left. never looked right next to it on the higher pump, im an idiot. well i put it together and it fit good. it runs smoother but it can be my head.
I wish I could have posted this earlier. :rlaugh:
