Alright well I had just a little bit of time to work on the car so I got the tank pulled down and all but one "connection" not taken off...it is the one (if looking from back of car to the front)...that is in front of the fuel pump assembly...how does that thing pull off...(remember I'm not talking about the fuel pump assembly (two fuel lines) but the thing in front...don't know how to explain it any better...does it pull off?
And also...I looked through the filler neck grommet and you can see the fuel pump in there...now I see a black wire and red wire in there (looks new but gasoline keeps them clean
)...does that mean there is aftermarket fuel pump (done by the previous owner?) in there or do the stock fuel pumps have that black and red wire...
And if that is normal...how do I wire the red and black wires (Walbro 190lph) onto the fuel pump...will I be able to tell when I pull the old fuel pump out how to install the new one?
)...does that mean there is aftermarket fuel pump (done by the previous owner?) in there or do the stock fuel pumps have that black and red wire...And if that is normal...how do I wire the red and black wires (Walbro 190lph) onto the fuel pump...will I be able to tell when I pull the old fuel pump out how to install the new one?
be sure to look how everything is set up and where the fuel pump sits in the tank, and just put everything back the same way. once you get it out it should be easy to see where everything goes. good luck!!
