Ok... so the fuel pump fuse keeps blowing every time I try to start the motor. The engine turns over fine, but wont start. The fuse blows before the pump even pressurizes the system. I had the battery tested and it tested "good" but only had 400 cranking amps out of a rated 800 cranking amps. So I charged the battery and the fuse still blew before the pump even turned on to pressurize the system. I've even tried a 30 amp fuse and that blew too (it's only supposed to have a 20 amp).
The first time this happened, I replaced the fuse (with a 20 amp), and it ran fine. A couple days later, I started the car and the fuse blew again after it ran fine for a few minutes.
I'm not sure where else to look...
Any ideas?
Any ideas?
