Fuel Pump Help Needed
  • Thread starter Thread starter BTG
  • Start date Start date May 20, 2005
BTG
20
CT
May 20, 2005
  • May 20, 2005
I have a mis fire between 2K and 3K RPM's. Can this be a result of a bad fuel pump? There is a whine in the rear on occassions. I have changed the spark plug wires twice and I have a new rotor, cap, plugs, pcv. I also checked the spark plugs for any cracks.
If you recommend a fuel pump...please let me know which one and where the best place to buy it is.
Mods
Cold Air intake
Future Mods
Gears 3.73
Cobra Intake
stang22
1,318
Washington, D.C.
May 20, 2005
  • May 20, 2005
Have you replaced the fuel filter yet? Any trouble codes from the computer? What's is your voltage on the TPS set to? 02 sensors? Just some things to check before you run out a buy a fuel pump.
Tim
BTG
20
CT
May 20, 2005
  • May 20, 2005
I had the codes checked and everything was fine. I just replaced the fuel filter.
stang22
1,318
Washington, D.C.
May 20, 2005
  • May 20, 2005
What type of plugs are you running and what are they gapped at? A couple of years ago I had a random miss around 3000rpm and it turned out to be crappy plugs. A couple of months ago I had the same problem, but this time it was the TFI module. I would check the voltage on the TPS.
BTG
20
CT
May 20, 2005
  • May 20, 2005
I will check the voltage to the TPS. I also put a tire pressure gauge on the schrader valve behind the distributor and it read 30 PSI at idle....if that means anything.
M
Electrical 93 5.0 No Injector Pulse
  • machinermac
  • Jul 26, 2026
Fox 5.0 Mustang Tech Aug 1, 2026
Willybill32
K
Resolved Weird sound coming from a freshly rebuilt 5.0L
  • karhoot
  • Jun 24, 2026
Fox 5.0 Mustang Tech Jun 27, 2026
Mac131
J
i need help
  • JK.
  • Oct 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 28, 2026
JD1964
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
  • dan50
  • Jul 18, 2026
dan50
