Looking at some maf sensors and injectors to feed the h/c/i I plan on. The heads are afr 165s, the cam will be an ed curtis custom cam (sorry ed about the delay, had a few problems I needed to take care of, I will work on getting you the money shortly) and a edelbrock RPM intake. Would 24lb injectors be enough to feed it? I assume Pro-M is back in business, and make good maf sensors. Is that who you guys would go with in my shoes?
What about fuel pumps? Would a 190lph be sufficient or would a 255 be ok? I'd like to top it off with a wet shot of gas, after the motor is running good, and the suspension is in check. After that it's off for the tuning. Thanks.
