Fuel pump not running right
  • Thread starter Thread starter jpe
  • Start date Start date Mar 8, 2023
J
jpe
  • Mar 8, 2023
I have a 01 bullitt that I can’t get the fuel pump to work right.
I have 12 volts all the way to the pump and have checked both wires from the pcm back and they work along with jumped the inertia switch but the pump won’t turn on.
Previous owner had the red/black wire grounded and that makes the pump run but it always runs as long as the key is on.
What else can I check to get this to work like it’s supposed to?
Thanks
D
Deleted member 38176
Mar 11, 2023
  • Mar 11, 2023
Sounds like the previous owner screwed up the system. Get a new pump
J
jpe
  • Mar 11, 2023
Already did and the pump works if you ground the red/black wire but is on all the time
weendoggy
5 Year Member
Jan 14, 2019
198
57
38
Aptos, CA
Mar 11, 2023
  • Mar 11, 2023
The returnless system is controlled by the CCRM and FPDM. The CCRM powers the FPDM via the Inertia Switch and sends information to the PCM and is monitored by the FRPT (fuel rail pressure tansducer). This is all sent via hyperspacelight through the PCM to modulate the pump cycles, like a variable switch. So, you have some checking to do to find out what someone did/didn't do to the system. In your case, if it's running full force all the time, it's been tampered with.
Shuttleman83
239
USA
Mar 11, 2023
  • Mar 11, 2023
There is a ground from ECU to fuel injectors which can cut off fuel, also, the crank sensor as well. Check both.
J
jpe
  • Mar 11, 2023
I just don’t know what or how I should be checking on this…I hate this design and will probably never buy another like this because of the stupidity they engineered.
I have owned 21 mustangs and this is the dumbest thing I have ever came across.
Please advise how and what to check
Thankyou
Shuttleman83
239
USA
Mar 11, 2023
  • Mar 11, 2023
You can remove the ground and clean it, try resetting your PCM for 1-2 hours via battery cable removal, also check wiring and volts to the crank sensor. And finally, check FPDM.
Shuttleman83
239
USA
Mar 11, 2023
  • Mar 11, 2023
Have you verified the CCRM is working 100%? There is also an underhood fuse that controls fuel pump, make sure it has 12v and
Check this link below for more info.
BULLITT Archive Template
The 2001 Ford Mustang BULLITT GT.
www.bullittarchive.com
J
jpe
  • Mar 19, 2023
If the crank sensor wasn’t working would it not run or have other issues?
I replaced the fpdm from another known running car and still the pump will not turn on.
Is there any way of checking the pcm to see if it is operating correctly?
Shuttleman83
239
USA
Mar 19, 2023
#10
  • Mar 19, 2023
  • #10
IIRC the crank sensor sends signal to the injectors and or the pcm when cranking, the timing of the cams with the cam sensor is important also.
J
jpe
#11
  • Mar 19, 2023
  • #11
It runs fine if you ground the red and black wire right by the tank. I’m wondering if the pcm isn’t sending anything to the fpdm…
Shuttleman83
239
USA
Mar 19, 2023
#12
  • Mar 19, 2023
  • #12
There is a fuel pump ground on the pcm check that out.
J
jpe
#13
  • Mar 19, 2023
  • #13
I cleaned the ground wires that are connected to the pcm but nothing changed…I hate ford for this dumbass idea
Bullitt347
I have been doing it wrong this whole time
3,977
2,959
194
Middle of Maine
Mar 19, 2023
#14
  • Mar 19, 2023
  • #14
It is only a "dumbass idea" because you do not understand it.
If you knew the reasons for why this system is used, you would appreciate why it was implemented.
J
jpe
#15
  • Mar 19, 2023
  • #15
So then tell me about this and why it isn’t working correctly sir
Bullitt347
3,977
2,959
194
Middle of Maine
Mar 19, 2023
#16
  • Mar 19, 2023
  • #16
Did you even check the link in post #8?
It has a very detailed diagnostic routine laid out for the 01' Bullitt Mustang.
If you follow that diagnostic routine I am sure you will find the problem.
J
jpe
#17
  • Mar 19, 2023
  • #17
Yes I did before I even made the first post but I have power to the pump it just won’t run unless the red and black wire is grounded so that didn’t help me much…
I have had 2 different fuel pumps and tanks in the car with the same result.
FUEL PUMP ALWAYS ON
  • Scwhitten
  • Jun 6, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jul 4, 2026
manicmechanic007
L
2003 mustang v6 3.8 fuel issue
  • lacole1
  • Jul 20, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jul 26, 2026
apple99Mustangdude
A
1999 Mustang GT - No Start- Need help understanding the fuel pump circuit and how it works
  • 99gtGuy
  • Nov 4, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 7, 2025
04newedge-
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Yesterday at 2:52 PM
JohnKay
J
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
