fuel pump problem
  • Thread starter Thread starter leelahg
  • Start date Start date Apr 5, 2005
leelahg
  • Apr 5, 2005
my boyfriend recently hooked up aftermarket fog lights on his 88 mustang gt. they are hooked up to a toggle switch. while in the process of doing that he had the factory alarm pulled down and never tucked all the wires and everything back the way they were. I drove the car to the store and back and the next day the fuel pump would not turn on. the car tries to turn over but the fuel pump never kicks on. does anyone have any suggestions on what he should try?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Apr 5, 2005
  • Apr 5, 2005
The car year and any modifications are needed to assist you. The wiring diagrams & wire colors changed several times during the 5.0 Mustang's lifetime.
leelahg
  • Apr 5, 2005
1988 mustang gt hatchback. no mod's except for flowmasters i think.
89 Saleen#455
519
New England
Apr 5, 2005
  • Apr 5, 2005
1. Most likely it's the alarm, but check the inertia cutoff switch located behind the trim panel in the rear hatch area. Sometimes depressing the switch will reactivate the pump. If not go to step 2.
2. Disconnect the aftermarket alarm and try starting the car. If the fuel pump still does not energize, you could have a faulty fuel pump relay. I know on my 89 the fuel pump relay is under the drivers seat. Not sure on the 88's. Also check to see that the fuse for the fuel pump has not been blown. It's possible it could have shorted out when he pulled down the alarm harness. If that doesn't do the trick, I would suspect the fuel pump went bad. Has the fuel pump been replaced in the past?
D
Daggar
3,902
  • Apr 5, 2005
I'd also suggest to your BF that running that kind of current through an interior toggle switch isn't such a hot idea either. I'm hoping that he's got and underhood relay somewhere?
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Apr 5, 2005
  • Apr 5, 2005
Fuel pump electrical Troubleshooting 86-90 models
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 5-20 seconds and shut off. To trick the fuel pump into running, find the ECC test connector and jump the connector in the lower RH corner to ground. See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html for a description of the test connector. If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. A tire pressure gauge can also be used if you have one - look for 37-40 PSI. Beware of fire hazard when you do this.
No fuel pressure, possible failed items in order of their probability:
A.) Tripped inertia switch – press reset button on the inertia switch. The hatch cars hide it under the plastic trim covering the driver's side taillight. Use the voltmeter or test light to make sure you have power to both sides of the switch
B.) Fuel pump power relay – located under the driver’s seat in most stangs built before 92. On 92 and later model cars it is located below the Mass Air Flow meter.
C.) Clogged fuel filter
D.) Failed fuel pump
E.) Blown fuse link in wiring harness. Use a voltmeter to measure the voltage drop across them. There should be less than .75 volt drop across a fuse link.
F.) Fuel pressure regulator failed. Remove vacuum line from regulator and inspect for fuel escaping while pump is running.
The electrical circuit for the fuel pump has two paths, a control path and a power path.
The control path consists of the inertia switch, the computer, and the fuel pump relay coil. It turns the fuel pump relay on or off under computer control. The switched power (red wire) from the ECC relay goes to the inertia switch (red/black wire) then from the inertia switch to the relay coil and then from the relay coil to the computer (tan/ Lt green wire). The computer provides the ground path to complete the circuit. This ground causes the relay coil to energize and close the contacts for the power path. Keep in mind that you can have voltage to all the right places, but the computer must provide a ground. If there is no ground, the relay will not close the power contacts.
The power path picks up from a fuse link near the starter relay. Fuse links are like fuses, except they are pieces of wire and are made right into the wiring harness. The feed wire from the fuse link (orange/ light blue wire) goes to the fuel pump relay contacts. When the contacts close because the relay energizes, the power flows through the contacts to the fuel pump (light pink/black wire). The fuel pump has a black wire that supplies the ground to complete the circuit.
Remember that the computer does not source power for any actuator or relay, but provides the ground necessary to complete the circuit. That means one side of the circuit will always be hot, and the other side will go to ground or below 1 volt as the computer switches on that circuit.
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host)
http://www.veryuseful.com/mustang/tech/engine/images/88-91eecPinout.gif
Now that you have the theory of how it works, it’s time to go digging.
Look for 12 volts at the Orange/Lt. Blue wire (power source for fuel pump relay). No voltage or low voltage, bad fuse link, bad wiring or connections. There is a mystery connector (one I haven’t found) under the dash somewhere, between the fuel pump relay and the fuse link.
Turn on the key and jumper the fuel pump test connector to ground as previously described. Look for 12 volts at the Light Pink/Black wire (relay controlled power for the fuel pump). No voltage there means that the relay has failed or there is a broken wire in the relay control circuit.
Check the Red/black wire, it should have 12 volts. No 12 volts there, either the inertia switch is open or has no power to it. Check both sides of the inertia switch: there should be power on the Red wire and Red/Black wire. Power on the Red wire and not on the Red/Black wire means the inertia switch is open.
The Tan/Lt Green wire provides a ground path for the relay power. With the test connector jumpered to ground, there should be less than .75 volts. Use a test lamp with one side connected to battery power and the other side to the Tan/Lt Green wire. The test light should glow brightly. No glow and you have a broken wire or bad connection between the test connector and the relay. To test the wiring from the computer, remove the passenger side kick panel and disconnect the computer connector. It has a 10 MM bolt that holds it in place. With the test lamp connected to power, jumper pin 22 to ground and the test lamp should glow. No glow and the wiring between the computer and the fuel pump relay is bad.
In cases where the pump won't turn off, it is usually because of the Tan/Lt Green wire is shorted to ground somewhere, causing the pump to remain on.
If and only if you have followed the test procedure to this point and still haven’t found the problem, the computer is suspect.
leelahg
  • Apr 5, 2005
Thanks so much for the info. One more quick question though, the foglights are hooked up to a toggle switch and dagger had stated something about an "underhood relay somewhere" for them. What an where is that generally supposed to be?
89 Saleen#455
519
New England
Apr 5, 2005
  • Apr 5, 2005
This link will help explain the need for a relay on your fog lights.
http://www.corral.net/tech/maintenance/foglights.html
leelahg
  • Apr 5, 2005
thanks. i will pass all this info on to my boyfriend. thanks for the help, i really appreciate it.
leelahg
#10
  • Apr 13, 2005
  • #10
alarm and a few other misc fried wires + bad fuel pump relay were to blame. the car is up and running again. thanks for the replies......later!!!!!
  • Mindseye007
  • Aug 16, 2026
Mindseye007
  • brandyn200
  • Jun 20, 2026
AeroCoupe
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
FUEL PUMP ALWAYS ON
  • Scwhitten
  • Jun 6, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 5, 2026
Scwhitten
Fox won't crank over and fuel pump won't kick on.
  • djj62478
  • Jun 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
General karthief
