Fuel Pump Problems.
  • Thread starter Thread starter DarkProphet
  • Start date Start date Mar 11, 2007
DarkProphet
391
Quakertown, PA
Mar 11, 2007
  • Mar 11, 2007
Hey guys, I'm posting this one for a friend. His car is an 87 converted to mass air. It has been through alot (had 200k on first stock engine), and recently got a new engine, a stock long block. Now the problems. When the key is turned to on, the fuel pump runs like it is supposed to, but never shuts off. It just keeps running until you turn the key off. There are no fuel leaks and almost everything has since been replaced. None of the previously mentioned parts changed or fixed anything. When the car is running, it has 40lbs of fuel pressure but drops to 25 when you start to drive. The engine wont go over 2500 rps either. He regrounded the fuel pump and checked all the other grounds too. Any ideas? Hes replaced engines before and is pretty good with mustangs, but none of us have any ideas for this one. Thanks
HISSIN50
34
129
Mar 11, 2007
  • Mar 11, 2007
If no other sensors stay hot with the key off, a latched FP relay is possible.
If other sensors stay hot, a latched EEC relay is possible as well.
I'd probe the FP relay socket to see what the control side of the relay is doing. If dead (no EEC relay supplied 12 volts or ground pulse) but you have a running pump, a latched FP relay is likely.
If the control side has ground and 12 volts, a latched EEC relay or other issue is more likely.
Good luck.
DarkProphet
391
Quakertown, PA
Mar 13, 2007
  • Mar 13, 2007
The pump doesn't stay on with the key off. The problem is that the fuel pump doesn't turn off when it reaches presssure. Like when you turn the key to on, the fuel pump only runs for a second. His runs constantly no matter what, untill you turn the key off. When his car is idling, it stays at 40lbs of fuel pressure. When you start reving it, the fuel pressure drops to 25lbs.
HISSIN50
34
129
Mar 13, 2007
  • Mar 13, 2007
For the pump not priming-out (but continuing to run), check the ground wire from the computer to the FP relay. This same wire goes to the self-test connector and might have shorted to ground (or someone may have jumped the wire to ground at the STC - that is why it's there).
The pressure drop can be a weak pump, clogged fuel filter or bad FPR. It takes some diagnostics (I'd swap fuel filters if in doubt, then carefully use fuel line crimpers on the return line to see if pressure holds. If so, that can suggest a FPR passing too much fuel).
Good luck.
Aryan15
236
CA
Mar 14, 2007
  • Mar 14, 2007
Id check the fuel pressure regulator.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Mar 14, 2007
  • Mar 14, 2007
Fuel Pump Troubleshooting for 86-90 Mustangs
Clue – listen for the fuel pump to prime when you first turn the ignition switch on.
It should run for 5-20 seconds and shut off. To trick the fuel pump into running,
find the ECC test connector and jump the connector in the lower RH corner to
ground.
If the fuse links are OK, you will have power to the pump. Check fuel pressure –
remove the cap from the Schrader valve behind the alternator and depress the
core. Fuel should squirt out, catch it in a rag. A tire pressure gauge can also be
used if you have one - look for 37-40 PSI. Beware of fire hazard when you do this.
No fuel pressure, possible failed items in order of their probability:
A.) Tripped inertia switch – press reset button on the inertia switch. The hatch
cars hide it under the plastic trim covering the driver's side taillight. Use the
voltmeter or test light to make sure you have power to both sides of the switch
B.) Fuel pump power relay – located under the driver’s seat in most stangs built
before 92. On 92 and later model cars it is located below the Mass Air Flow meter.
C.) Clogged fuel filter
D.) Failed fuel pump
E.) Blown fuse link in wiring harness. All the applicable fuse links are in the wiring
harness up next to the starter solenoid.
F.) Fuel pressure regulator failed. Remove vacuum line from regulator and inspect
for fuel escaping while pump is running. If you find fuel escaping, the regulator has failed.
The electrical circuit for the fuel pump has two paths, a control path and a power
path.
The control path consists of the inertia switch, the computer, and the fuel pump
relay coil. It turns the fuel pump relay on or off under computer control. The
switched power (red wire) from the ECC relay goes to the inertia switch
(red/black wire) then from the inertia switch to the relay coil and then from the
relay coil to the computer (tan/ Lt green wire). The computer provides the ground
path to complete the circuit. This ground causes the relay coil to energize and
close the contacts for the power path. Keep in mind that you can have voltage
to all the right places, but the computer must provide a ground. If there is no
ground, the relay will not close the power contacts.
The power path picks up from a fuse link near the starter relay. Fuse links are like
fuses, except they are pieces of wire and are made right into the wiring harness.
The feed wire from the fuse link (orange/ light blue wire) goes to the fuel pump
relay contacts. When the contacts close because the relay energizes, the power
flows through the contacts to the fuel pump (light pink/black wire). The fuel pump
has a black wire that supplies the ground to complete the circuit.
Remember that the computer does not source any power to actuators, relays
or injectors, but provides the ground necessary to complete the circuit. That
means one side of the circuit will always be hot, and the other side will go to
ground or below 1 volt as the computer switches on that circuit.
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring http://www.veryuseful.com/mustang/tech/engine/
Ignition switch wiring
Fuel pump, alternator, ignition & A/C wiring
Computer,. actuator & sensor wiring
Now that you have the theory of how it works, it’s time to go digging.
Look for 12 volts at the Orange/Lt. Blue wire (power source for fuel pump relay).
No voltage or low voltage, bad fuse link, bad wiring, bad ignition switch or ignition
switch wiring or connections. There is a mystery connector somewhere under the
driver’s side kick panel, between the fuel pump relay and the fuse link.
Turn on the key and jumper the fuel pump test connector to ground as previously
described. Look for 12 volts at the Light Pink/Black wire (relay controlled power
for the fuel pump). No voltage there means that the relay has failed, or there is a
broken wire in the relay control circuit.
Check the Red/black wire, it should have 12 volts. No 12 volts there, either the
inertia switch is open or has no power to it. Check both sides of the inertia
switch: there should be power on the Red wire and Red/Black wire. Power on the
Red wire and not on the Red/Black wire means the inertia switch is open.
The Tan/Lt Green wire provides a ground path for the relay power. With the test
connector jumpered to ground, there should be less than .75 volts. Use a test
lamp with one side connected to battery power and the other side to the
Tan/Lt Green wire. The test light should glow brightly. No glow and you have a
broken wire or bad connection between the test connector and the relay. To test
the wiring from the computer, remove the passenger side kick panel and
disconnect the computer connector. It has a 10 MM bolt that holds it in place.
With the test lamp connected to power, jumper pin 22 to ground and the test
lamp should glow. No glow and the wiring between the computer and the fuel
pump relay is bad.
If all of the checks have worked OK to this point, then the computer is bad. The
computers are very reliable and not prone to failure unless there has been
significant electrical trauma to the car. Things like lightning strikes and putting
the battery in backwards or connecting jumper cables backwards are about the
only thing that kills the computer.
  • Mindseye007
  • Aug 16, 2026
Mindseye007
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
  • brandyn200
  • Jun 20, 2026
AeroCoupe
J
Having fuel issues
  • Jbands2v
  • Nov 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Yesterday at 5:24 PM
Mcmahst
Engine Fuel not pumping
  • Creomod
  • Apr 13, 2026
  • 2 3
2K
Fox 5.0 Mustang Tech Jul 22, 2026
