  • SN95 4.6L Mustang Tech
fuel pump question
  • Thread starter Thread starter SkOoTcHe
  • Start date Start date Apr 13, 2004
SkOoTcHe
24
pa
Apr 13, 2004
  • Apr 13, 2004
Ok I'm stuck on this.. In the near future. after a alot of mods to my motor.. I'm planning on adding a supercharger with like 15psi of boost and some big ass injectors so i need more fuel to feed the beast.. Since my 01 gt has a returnless fuel system (or so i have been told) who or where or how can i get a 255gph fuel pump that will work on my car... I've heard of people using 2 focus fuel pumps . but i'd rather do it the right way.. any ideas
jstreet0204
939
Winston Salem, NC
Apr 13, 2004
  • Apr 13, 2004
Here is an article where they compare several different setups. Most would agree the best way to go is probably the 03 cobra tank and pumps. It will set you back about $700 for part alone though.
http://www.modulardepot.com/articles.php?aid=27
Blakers01GT
Master of the Clubhead
2,110
Brown Deer, WI
Apr 13, 2004
  • Apr 13, 2004
15 lbs of boost on a stock bottom end!?
Man do some more research before you start worrying about a cobra fuel pump. If you "want to do it right" I hope you plan on rebuilding your bottom end to all forged if you wanna even be near 15 lbs of boost. Understand a stock bottom end can only handle so much boost, 8-10 lbs MAX. most guys run 6-8 lbs on a stock bottom end, which I assume you have. Since your car has been sprayed hard as well(100 shot) then I assume your motor doesn't need much more abuse, much less 15lbs from a blower
I don't think the fuel pump needs to be touched if you just run 8 lbs on the stock bottom end, but if you plan on rebuilding to get close to that boost, you should get the cobra fuel pump, billett oil pump gears etc. good luck
SkOoTcHe
24
pa
Apr 13, 2004
  • Apr 13, 2004
like i said Alot of engine mods. this includes a forged cobra crank eagle rods 8.1:1 compression forged pistions triple valve springs. you know the hard stuff hopefully it all holds together. i have alot of it figured out i just don't know about the fuel pump
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
Fuel Damper, 2003 Mustang GT
  • bmmckl
  • Dec 19, 2025
1996 - 2004 SN95 Mustang -General/Talk- Dec 19, 2025
bmmckl
