  • 1994 - 1995 Specific Tech
Fuel Pump Relay
  • Thread starter Thread starter davis95gt
  • Start date Start date Nov 14, 2004
D
davis95gt
  • Nov 14, 2004
Hello, I have a 95 gt...for quite some time, it would take a few cranks to start and would occasionally run somewhat rough while the engine was cold. Finally got a code scanner and it showed "Primary Fuel Pump Relay Failure". Now my problem is I dont have a clue as to where the fuel pump relay is located! I seen on autozone's website it should be located on the driver's side in front of the strut tower in the relay block, however the only relay's that are in there are the Horn relay, Starter relay, and Fog lamp relay. I've pulled the driver's side seat thinking it may be similar to earlier Mustangs but found nothing. Also seen in a repair manual that there is a CCRM that plugs into somewhere near the electrical fan, which includes a fuel pump relay but it does not even closely resemble the one that i bought. If anybody could help my out i'd greatly appreciate it!
stang_gt_1994
2,723
Powder Springs, GA (30 min. from Atlanta)
Nov 15, 2004
  • Nov 15, 2004
It is behind the coolant overflow tank and between the alternator. It is a little black box that is about 5"X4".
D
Fox 88 foxbody no power to red and black wire at fuel pump relay
  • drod88
  • Dec 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 2, 2025
Mcmahst
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
R
No prime on fuel crazy issue fixed!
  • Robman8028
  • Jun 28, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 29, 2025
Robman8028
R
Help! Fuel pump not turning on.
  • Steezin636
  • Dec 13, 2024
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 3, 2025
Mcmahst
J
Resolved Fuel pump not priming ground detected on circuit
  • jpfox
  • Oct 5, 2024
Fox 5.0 Mustang Tech Oct 10, 2024
jpfox
J
