fuel pump what size
stevesLX
373
cincinnati
I think I am in need of a new fuel pump or perhaps just a new fuel filter. I really dont know. What I do know is I just bought a BBK AFPR I have it set at 35LBS whenever I give the car gas the pressure guage drops down into the 20's and stays there until I let off the gas and then the pressure guage goes back up into the 30's. So maybe someelse here can help me out on this. I know the fuel filter looks pretty rough. The one that is on there is what was on there when I bought the car. Iam not sure how old it is. The car is a 89 LX. The last owner claims to have had a bigger fuel pump put on the car but its hard telling with this guy. The car has 24# injectors. I dont know how to tell if the fuel pumps bad and if it is I dont even know what size fuel pump it should have for those injectors. Any help would be great. Another thing why I 'm thinking about it is if I turn the key all the way forward without starting the car I can hear the pump kick on. Now should the fuel pressure on my guage still be at zero or should it go up. Mine is at zero until the car is actually started.
You should start getting fuel pressure with the key on and engine off (KOEO). The fuel pressure is supposed to be at 39-41 psi with the vacuum line disconnected. This is also what you should see at KOEO after the pump runs. If the fuel pump is weak it might not be able to keep up with the larger injectors while the engine is running.
When I turn key on engine off my pressure guage doesn't move. I haven't tried it with the vacum line off of it. But I know with it on it it doesn't until you actually start the car. When I turn the key forward you can hear the fuel pump kick on
O.K. so I was wrong. I got home tonight and turned my key forward and my fuel pressure guage that I have mounted to my AFPR moves up to 20. When I start it sits at 30 on the button with the vacum line nconnected to it. With the vacum line off the AFPR the guage goes to 35 which is where I have the pressure set. So with the vacum hooked back up if I give it gas the pressure guage drops to around 25-28 and stays there until I let off the gas and then it returns back to 30. I changed the filter but that didn't help anything. I am assuming that its the pump thats causing this. I just replaced the AFPR this past Saturday. Its a BBK. If I do need a new pump what size do I need for 24#injectors and I have a nitrous kit to add also.
I would set the fuel pressure to a stock setting (38-39 PSIG with the vac line removed and capped). This should shift the idle pressure above 30 PSIG, which is where it should be.
If you have fuel line crimpers, you can do a crude FPR test.
Good luck.
