fuel pump
Ar_sn95
28
fuel pump, need help!!!!!!
Tonight after work I went to start my car up and it wouldn’t start after a while I realized the fuel pump wasn't coming on so I checked all the fuses and they were all good, so my ? is what are the next things I need to check
The inertia switch and the wiring at the CCRM is where I would start.
You can also jump the pump at the self test connector.
Good luck.
i found the switch but the red part of it is pressed all the way down and i cant get it to come back up or go down any further, and how exactly do you do a self test on the fuel pump?
