  • SN95 4.6L Mustang Tech
??fuel pump??
  • Thread starter Thread starter blck96svt
  • Start date Start date Aug 29, 2006
blck96svt
  • Aug 29, 2006
how much would a 255 lph bbk intank pump benifit me on my 2000 gt with vortech blower running 10 lbs. and a 75mm TB.
RandyStinchcomb
1,159
Randallstown, Md
Aug 30, 2006
  • Aug 30, 2006
I would not mess wth it. get a SVT Focus pump, cheaper and more reliable
stangGT97
1,299
Boston area, MA
Aug 30, 2006
  • Aug 30, 2006
edit: nvm - i read his post then saw his user name and thought he had a 96 cobra, not 2000 gt
Some of this will depend on if you've maxed your fuel system already... if you have significant fuel pressure drop off as the rpms climb, then I think an SVT focus pump will benefit you. The last thing you want it to start detonating @ 5000+ rpm. That being said, I can't comment on the BBK pumps, but if for some reason you decide to go that route, be sure you get a pump for a returnless fuel system.
nwapache
313
Seattle,WA
Aug 30, 2006
  • Aug 30, 2006
Are you getting fuel pressure drop off at WOT? If not, you have no worries yet....If you do have drop off, then you want to look at fuel system upgrades. Larger injectors, and a better pump. Depending on how much HP you are going for you can use the Focus SVT pump which will handle up to 450hp along with 42lbs injectors.
blck96svt
  • Aug 30, 2006
#1 the thing is i already have the pump but its not installed and i got it for free so i guess it wouldnt hurt except my wallet on gas if i upgrade injectors and #2 i have sputter that feels like a drop of boost between 3-4 shift on WOT, when i smash it, it has a second where it falls on its face(and its not T/C), only gauge i have is boost and it drops but not to zero or vaccum, seems normal like a normal drop like every other shift so im guessing it could be fuel pressure, i need to get a guage or i can ge the WDS from my dealership and watch PIDS
blck96svt
  • Aug 30, 2006
plus i had it dynoed at 363 and 360 tq. with only 75mm TB and vortech
nwapache
313
Seattle,WA
Aug 30, 2006
  • Aug 30, 2006
damn, nice numbers! ...get your fuel pressure checked for sure. I don't know squat about the particular pump...but if you need it, use it.
blck96svt
  • Aug 30, 2006
thanks for all the reply's
fastangboi
My first set of nuts vibrated themselves off.
Jul 26, 2006
274
Slowville
Aug 31, 2006
  • Aug 31, 2006
All i know is that you cant use the return style pumps on the returnless systems. it will burn the pump up in a heartbeat
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
C
98 gt fuel pressure issues
  • chasecollier1984
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 2, 2026
chasecollier1984
C
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
