fuel pump??????
Beasty306GT
671
Oxford,Mass
Well my question to everyone is i got to replace my gas tank and i bought my buddies tank with a new trick flow 255 lb pump..Thing is i got stock injectors with no fuel regulater. Will it be a problem if i run a the tank with a bigger pump with no regulator...i plan on droppin in my 306 with aftermarket everyhitng for the fuel wwith 30 lb injectors ....but the tank leaks and i gotta replace it... So do i need a regualtor to have it work properly or will it pump gas to quick???
The stock system has a fuel pressure regulator, but it is not adjustable. This is not a problem and you can use a 255 lph pump with it without any worry.
