  • SN95 4.6L Mustang Tech
Fuel pump?
  • Thread starter Thread starter HurricaneJesus
  • Start date Start date Oct 16, 2010
HurricaneJesus
160
Springfield
Oct 16, 2010
  • Oct 16, 2010
Car turns but won't start. I changed the fuel filter a few weeks ago after a similar problem. Changed the fuse for the fuel pump and made sure the inertia switch wasn't tripped. Had my wife turn the key while I had my ear to the tank and couldn't hear the fuel pump 'whirring'. That's gotta be the problem, right? I just want to be sure before I spend 100 bucks and go through what is sure to be a bitch of an operation here....
wmburns
SN Certified Technician
Aug 14, 2009
5,892
514
204
Houston Texas
Oct 16, 2010
  • Oct 16, 2010
Confirm that when the key is placed into the "on" position, that the theft light goes out after a 3 second "prove out". The theft light should not blink during cranking.
Review the following thread. It contains detailed instructions on how to confirm a bad fuel pump.
http://www.stangnet.com/mustang-forums/824672-fuel-delivery-issues.html
HurricaneJesus
160
Springfield
Oct 17, 2010
  • Oct 17, 2010
Thanks for the info, sir! Def the fuel pump. OK so here I am, I've got the tank dropped and the ring on top unbolted...how am I getting this thing off? Does it turn somehow? Do I pry it?
HurricaneJesus
160
Springfield
Oct 17, 2010
  • Oct 17, 2010
OK done with that but how do I actually get the assembly out of there?
HurricaneJesus
160
Springfield
Oct 17, 2010
  • Oct 17, 2010
OK nevermind, I got it!
HurricaneJesus
160
Springfield
Oct 17, 2010
  • Oct 17, 2010
Holy ****, man. After some cursing and a partial hernia getting the tank back in I got it done. Worked like a charm! I thought I could reuse the filler neck grommet since it didn't look bad but when I filled up I found out I was WRONG. Guess I'll get that tomorrow....after all that I'm tempted to just let a shop install it, though....lazy?
Three50won
1,135
64
69
Oct 17, 2010
  • Oct 17, 2010
Congrats man. I've done my pumps with help and it is def annoying. Doing it alone has got to be a nightmare, good job...
HurricaneJesus
160
Springfield
Oct 20, 2010
  • Oct 20, 2010
Any useful tips on replacing the grommet? Ford place quoted me $300 to replace it and the only way that happens is if they give me $300 worth of the parts counter chick. I'm hoping I can do it without dropping the tank again.
wmburns
Aug 14, 2009
5,892
514
204
Houston Texas
Oct 21, 2010
  • Oct 21, 2010
I paid less than $20 for a new grommet full price at the Ford parts counter.
Since you have done a fuel pump replacement, you have seen how everything is put together. I don't see how it's possible to replace the grommet without dropping the tank.
To anyone else reading this thread. The service manual calls for the old fuel tank grommet to be completely cut away before attempting to remove the filler neck from the tank. This is done for a number of reasons. Over time, the grommet will bond to the filler neck. This make removal difficult and the likelyhood of the old grommet re-sealing is nil (as in this case). The other reason is to prevent damage to the filler neck check valve. If the filler neck is pulled out while the grommet is in place, this will damage the anti-rollover/anti-siphon check valve. This check valve can not be serviced without replacing the entire filler neck assembly.
If dropping the fuel tank, recommend following the service procedures. Cut the old grommet away. Re-install the tank using a new grommet.
HurricaneJesus
160
Springfield
Oct 23, 2010
#10
  • Oct 23, 2010
  • #10
As much as I tried to prove you wrong, that sucker wasn't coming out of there without dropping the tank. Almost but just short by a centimeter. I even tried just lowering the passenger side of the tank to get a better angle on it but nothing doing. After that, though it was pretty straightforward. A lil oil on the grommet and the filler neck didn't even put up a fight going in. Thanks for all the helpful info, everyone!
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
FUEL PUMP ALWAYS ON
  • Scwhitten
  • Jun 6, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jul 4, 2026
manicmechanic007
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
