Fuel Rail Connections
nero6
94
I can't seem to get the fuel rail connections to pull apart. I have the correct AC/Fuel line disconnect tools but when I push it in it does not move at all. I have sprayed some PB Blaster in the connections but still with no luck. Any suggestions on how to get these apart?
sometimes you have to spin or wiggle the tool into the spring to un lock it fully, also if you have the plastic tools, you may want to consider finding the aluminum ones.
Some of the plastic ones don't have a big enough lip to pop the lines off. Get a set with a deeper lip and they should pop right off. Just had the same problem 2 days ago
Right on, I am going to order a set of the metal ones. Hopefully I can get more leverage on the metal ones, the connection will not buge at all with the plastic ones, can't get the spring to compress at all.
