  • SN95 V6 Mustang Tech
Fuel Rail Crisis
  • Thread starter Thread starter AP1995V6
  • Start date Start date Oct 15, 2005
AP1995V6
547
Oxford, MS
Oct 15, 2005
  • Oct 15, 2005
Is there an easy way to take off the metal pipe that runs from the water pump to the firewall, which also happens to run over the fuel rail?
It turns out that it may have not been fuel injectors causing the poor gas mileage and poor performance. I had a huge hole in the pcv line on the passenger side.
AP1995V6
547
Oxford, MS
Oct 15, 2005
  • Oct 15, 2005
All done.
The EGR was a pain to work around, and I ended up having to bend it slightly to access the fuel rail on the passenger side only to run into the problem of getting it to line back up with upper intake. I should've just blocked it all off, but I wasn't sure how to block off the EGR tube in the exhaust manifold. My cousin has several egr plates, but I didn't want exhaust blowing out through that hole ;-)
I can't really tell a difference, but I'll know if I fixed the problem when I fill up again.
Fuel rail help
  • stang9150
  • Mar 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 5, 2026
stang9150
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
'04 V6 running rich excessively on both banks
  • 04DSGVert
  • Oct 26, 2025
SN95 V6 Mustang Tech Oct 27, 2025
04DSGVert
N
89 LX 5.0 Fuel Rail Recommendations
  • Ncarter
  • Oct 17, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 18, 2025
rednotch
C
Boosted Boss 302 HP/TQ
  • coltoncaskey12
  • May 24, 2026
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech May 24, 2026
coltoncaskey12
C
