Fuel Rail question?? (Pic inside)
  • Thread starter Thread starter asecretfile
  • Start date Start date Jul 18, 2008
asecretfile
228
  • Jul 18, 2008
87 GT MAF converted
I have been hunting an low idle/mostly stalling prob for a while now after doing a head swap. So I get the car started (barely) 500rpms having to stay on throttle a tad to keep it running and on light throttle I kept hearing a hissing from below the alternator sounded almost like a vacuum leak. Im not leaking any fuel but it sounded like it was coming from here. Is this how this connector is supposed to be seated, angled like that? I did have to move these to do the swap..I might have done something to them
thanks
LiquidGT
368
Near STL hell
Jul 18, 2008
  • Jul 18, 2008
Hissing under the alternator?
Check the vacuum line that goes to the charcoal canister/evap solenoid.
asecretfile
228
  • Jul 19, 2008
I say a hissing sound...what I mean is sounds like a vacuum leak right at the connector of the pictured fuel line. could this line be drawing in air without actually spilling fuel? because I dont have gas leaking but at low throttle I hear what almost sounds like a vacuum leak coming from this fitting
thanks
LiquidGT
368
Near STL hell
Jul 19, 2008
  • Jul 19, 2008
I dont think it has to do anything with fuel at all, there is a vacuum hose that goes from the very front of the intake to the charcoal canister on the pass side frame rail.
Matter of fact I believe the vacuum hose is hidden in the big plastic wire loom in the pic. Its in one of the wire looms anyway, I replaced it before.
N
Engine 86 GT no start/stall
  • nweber
  • Jul 28, 2026
Fox 5.0 Mustang Tech Jul 29, 2026
AeroCoupe
Electrical Code 29 again
  • Creomod
  • Jul 31, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
Creomod
Engine 91 mustang 302 Low acceleration car backfires pops and acts like it doesn’t want to take fuel
  • 1991Fox5.0
  • Oct 4, 2025
Fox 5.0 Mustang Tech Oct 6, 2025
1991Fox5.0
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
