  • SN95 4.6L Mustang Tech
Fuel rail removal
  • Thread starter Thread starter spederman
  • Start date Start date Apr 1, 2009
spederman
732
  • Apr 1, 2009
In the middle of my bullitt intake swap and going to put on the bullitt fuel rails. My question is that rubber crossover hose that connects the two fuel rails in the back of the motor, is that removable? I tried pulling on it, and it doesnt budge. What i also dont get is there are no clamps on that hose, wouldnt u think if there is fuel running thru it, that you would def want clamps so it doesnt ever loosen up and start spraying fuel?
Killa
1,006
56
49
Apr 1, 2009
  • Apr 1, 2009
remove the TB, then pull all the injector off, and then work your way to pull the whole fuel rail system off.
98stangv8
1,036
fayetteville, nc
Apr 1, 2009
  • Apr 1, 2009
You have to cut it...it won't pull apart...
I think that is what you are asking,...
spederman
732
  • Apr 1, 2009
Really? So then you have to buy another crossover tube for the fuel rails? Why would Ford use such a stupid design. Is their any aftermarket crossover tube's that would work?
birdman941
115
Gone
Apr 2, 2009
  • Apr 2, 2009
Rickyll7
718
  • Apr 2, 2009
You shouldn't have to remove those cross over tubes to remove the fuel rails. Just remove it as an assembly as stated above.
98stangv8
1,036
fayetteville, nc
Apr 2, 2009
  • Apr 2, 2009
I replaced the fuel rails on my 98 with those of a 97 so I could use a pressure regulator...you have to cut it...it won't pull off...it is bs...if you can't pull it off whole, you have to cut it...
spederman
732
  • Apr 3, 2009
cool. thanks for the help guys. maybe i wont pull it off then. there was just some surface rust or corrosion of some kind on the inside of the fuel rails and i was going to soak them in some of that evaporust stuff and see if it actually works.
GDawg
1,469
Nevada
Apr 3, 2009
  • Apr 3, 2009
I wouldn't recommend cutting or pulling it off. It's intended to be one piece.
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
Engine Motor swap from a 2003 Explorer
  • 1996mustang new
  • Oct 9, 2025
SN95 4.6L Mustang Tech Oct 16, 2025
squeak93
M
  • mnky99
  • Sep 5, 2025
mnky99
M
Electrical 88 EEC Injectors batch firing ?
  • Dustin 86GT
  • Dec 8, 2025
Fox 5.0 Mustang Tech Jan 8, 2026
gkomo
Finding all the bolts to remove the intake manifold on '98 GT
  • dochawk
  • Sep 27, 2024
1996 - 2004 SN95 Mustang -General/Talk- Sep 28, 2024
dochawk
