FUEL RAIL?
  • Thread starter Thread starter aod92
  • Start date Start date Jan 7, 2007
aod92
104
  • Jan 7, 2007
I heard that the 94-95 5 liter flow better than the 87-93 . Is this true? Has anyone else heard of this
Jaswir
578
Orlando, FL
Jan 7, 2007
  • Jan 7, 2007
never herd of this... should be the same...
bryce93lx
88
Luke AFB AZ
Jan 7, 2007
  • Jan 7, 2007
umm i think the stocker is good to like 400 horse so it's a non issue unless you are getting serious and then you should get a aftermarket rail anyways
W
~-Ws50's916-~
27
I Live in West Sacramento, Soon to be Citrus Heigh
Jan 7, 2007
  • Jan 7, 2007
From what I have heard, your stock fuel rails are just fine for up to 400+ HorsePower. When your getting serious with power and fuel, you can get a set of Aeromotive fuel rails. But those are pointless if your running just, heads cam cold air on your 302...
TheBocSez
652
Converse, TX
Jan 7, 2007
  • Jan 7, 2007
I have heard this also. The 94-95 rails are square as opposed to the round 86-93 rails and do look a little bigger. I have heard that the 94-95 will support up to 500 hp.
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Jan 8, 2007
  • Jan 8, 2007
Here is a good Write Up on the Swap.
http://www.duggerracing.com/techtips/rails/index.shtml
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Jan 8, 2007
  • Jan 8, 2007
stock is fine for a H/C/I 5.0 but if you want the look of aftermarket rails go for it and maby you will grow into them
millhouse
1,985
Simpsonville, SC
Jan 8, 2007
  • Jan 8, 2007
The stock rails are adequate for block splitting h/p with proper pressure.
flyinghi3
313
Manorville, LI
Jan 8, 2007
  • Jan 8, 2007
the 94-95 fuel line are bigger then the stock 87-93 fuel lines. the stock fuel line are good up to around 400-425hp after that your are pushing the stock rails. the 94-95 fuel rail will support 500+ hp. i have them on my car as i didnt want to spend a ton of money on aftermarket fuel rails, and you can pick up used 94-95 rail looking on the web for a decent price.
seijirou
2,417
DFW
Jan 8, 2007
#10
  • Jan 8, 2007
  • #10
But what about the feed and return lines on the car? What are the stock 87-93 lines good for?
millhouse
1,985
Simpsonville, SC
Jan 8, 2007
#11
  • Jan 8, 2007
  • #11
There are plenty that have pushed the the stock 87-93 fuel rails past 500rwhp with no issues.
The general concensus over on turbomustangs seems to be 500-550rwhp is reaching the upper limits of the stock 87-93 rails.
flyinghi3
313
Manorville, LI
Jan 8, 2007
#12
  • Jan 8, 2007
  • #12
i was running 480rwhp with the stock rails and was leaning out. like i said with the stock rails after 450hp you are starting to push the limits on them. the 94-95 rail are bigger and are able to hold more fuel. less of a chance of leaning out the motor.
flyinghi3
313
Manorville, LI
Jan 8, 2007
#13
  • Jan 8, 2007
  • #13
the feed and return line are just about in the same locating as the stock rails. i had to bend one of the lines the supply the rail just a little bit by hand. they connect right up just the the 87-93 lines.
millhouse
1,985
Simpsonville, SC
Jan 8, 2007
#14
  • Jan 8, 2007
  • #14
Keep in mind RWHP is relative to the power adder your using. Your leaning out at 480 rwhp while many turbo guys seem to be just fine past 550 rwhp. It's also a must to have proper fuel pressure. Some people seem to have no issues with just a high volume 255 pump while some need an additional inline.
seijirou
2,417
DFW
Jan 8, 2007
#15
  • Jan 8, 2007
  • #15
what I mean is hp support of the stock fuel lines, inbetween the rails and the tank.
flyinghi3
313
Manorville, LI
Jan 8, 2007
#16
  • Jan 8, 2007
  • #16
well i look at it this way. it cheep insurance. for $125 i got the rails and fuel pressure regulator, knowing that i have good enough fuel to supply the motor, and not have to worry about it.
also at the time i was running 42lb injectors with the stock rails. now i'm running 55lb.
flyinghi3
313
Manorville, LI
Jan 8, 2007
#17
  • Jan 8, 2007
  • #17
not to sure about this one
seijirou
2,417
DFW
Jan 8, 2007
#18
  • Jan 8, 2007
  • #18
Because I wonder. I can have rails and a pump as big as they get, but if the lines only flow to 500hp, that's all I'm going to get anyway.
Engine Hiccup at full throttle
  • keel
  • Jun 2, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
keel
Brakes 80 Mustang 4.2 rear chassis brake line for 5 lug conversion!
  • StangPowerLSX510
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 9, 2026
limp
L
Engine 85 GT Excessive Idle
  • lutzkecj
  • Sep 18, 2026
Fox 5.0 Mustang Tech Sep 21, 2026
86HO5.0
4.6 spitting o-rings out of 2 injectors
  • skidad
  • Sep 30, 2026
  • 2 3 4
2K
1996 - 2004 SN95 Mustang -General/Talk- Nov 4, 2026
skidad
What megasquirt kit to order
  • 74delta
  • Jul 4, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Aug 26, 2026
fasterthangas
F
