  • 1994 - 1995 Specific Tech
FUEL SENDER ROTTEN??
  • Thread starter Thread starter howiefisher
  • Start date Start date Jun 19, 2008
howiefisher
154
Ont Canada
Jun 19, 2008
  • Jun 19, 2008
so i had a fuel leak around the top of tank on right rear so i lowerd take down and bolth lines on sender rotten and the connecter is disinagrated as well as the wire plug that plugs into the connector it just fell off ??were can i get the plug that fits into sender ???junk yard ?just cut and splice the new one on ?also could this be what was causing my high rpm break up ??
H
Fuel starvation issues, 91 EFI to carb swap. Car dying after 1-3 gallons used. EFI tank, electric fuel pump, bypass regulator. Dual fed carb
  • hassler
  • Oct 11, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 12, 2025
nickyb
D
Running both lean and rich with O2 heat codes
  • Danceswithfire5
  • Aug 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 5, 2026
apple99Mustangdude
A
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
