I am looking to upgrade my fuel system in preparation for the addition of nitrous.
I have a mechanical pump 110 gph and I have been told running a regulator with this pump is not necessary.
My plan is to run AN-6 from the tank to the pump, and then AN-6 from the pump to the carb.
I have noticed that many of the dual feed lines are setup for AN-8 line, I am wondering if there is a reason I should run AN-8 from the pump to the carb?
Also, being that I have never used nitrous, does the additional fuel required for the nitrous also come from the same fuel source? I know a lot of guys run a separate fuel pump but at most I will be running a 100 shot. Do I just T into the line from the pump to the carb?
Also, I am thinking it would be a wise idea to run a fuel pressure guage. I want one I can see from inside the car, not one that screws into the dual feed line where it cant be seen while driving. Can I use a mechanical guage for this? If so, would I just run a separate line off the feed line (AN-4?) to the guage?
Please idvise me since this is all new to me. If you have any suggestions or recommendations as far as what guage to buy I would like to know.
