  • SN95 4.6L Mustang Tech
Fuel system question ??????
  • Thread starter Thread starter Zacharyx
  • Start date Start date Dec 10, 2006
Z
Zacharyx
35
  • Dec 10, 2006
If I wanted to do my fuel system once, what would it include. It has to be streeteable and support twin 67mm turbos. I was figuring 60# injectors would be a starting point, then what, oh and I would like to stay return style
Built98GT
211
OKC
Dec 10, 2006
  • Dec 10, 2006
03 cobra tank. Replace cobra pumps with bigger ones. How much power are you trying to make?
stangman
2,690
10
69
in a 3 bed, 2 bath
Dec 10, 2006
  • Dec 10, 2006
cobra tank, twin Ford GT pumps, larger fuel lines, larger fuel rails & you'll be good to go.
Z
Zacharyx
35
  • Dec 11, 2006
since there is never enough HP I am trying to keep from doing things over and over, I Know you have known friends or read threads where people go from the 19# to the 36# and then 42# injectors and now they are running out of injectors again. I figure if I build a fuel system capable of 1000hp then I will only have to do it once.
Both replies have the cobra tank and bigger pumps, would these still work return style or would the pumps burn out
Stan Weiss
347
Philadelphia, PA
Dec 11, 2006
  • Dec 11, 2006
What level / HP of power will you have when you do the fuel system modifications? If you put to large an injector on for the HP you have, at idle the computer will have trouble get the duty cycle small enough.
Don 95Vert
1,091
Delaware, OH
Dec 11, 2006
  • Dec 11, 2006
I'd go with 60's an SCT BA 2800 MAF - or a 2400 MAF with a Maf.ia. Then do the '03 Cobra tank and Ford GT fuel pumps - to get the fuel pumps to outflow the '03 Cobra pumps, you WILL need to run two FPDMs just like the GT's do. If you try to wire the GT pumps with one FPDM, they will flow a lot less and you may run into other problems too. Currently you have one FPDM. You also should do the wiring upgrade also. Should then support tons of power.
jstreet0204
939
Winston Salem, NC
Dec 11, 2006
  • Dec 11, 2006
Cobra pumps are for a returnless system. You have many more options with the return setup.
Z
Zacharyx
35
  • Dec 11, 2006
I will be in the mid 300 range when I do the upgrades, my tuner says he can get 60#s to work down there and I should not run out. I am looking at the aeromotive systems that MMR sells with the sumped tank i figure that would be a good starting point
Stan Weiss
347
Philadelphia, PA
Dec 11, 2006
  • Dec 11, 2006
As long as he can get them to work that is great. They will be good for 800 HP To 1150 HP based on the BSFC of your engine when modified.
DropTopPony
Noob Slayer
2,570
south jersey
Dec 11, 2006
#10
  • Dec 11, 2006
  • #10
Why is everyone saying Cobra tanks etc etc he has a 97...different fuel system. You should get a Walbro 255lph hp intank or equivelent pump along with an inline pump if your going high hp...the aeromotive stuff is really nice but expensive.
60#inj, SCT 2800, upgrade your fuel lines and rails...that sumped tank setup looks badass from the rear. I considered one myself but just went with the Walbro for now.
A
Fuel Capable fuel system for +600hp
  • Avia.tuned
  • Feb 24, 2026
SN95 4.6L Mustang Tech Feb 24, 2026
squeak93
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
identifying smog/fuel part on 1998 GT
  • dochawk
  • Jun 18, 2026
SN95 4.6L Mustang Tech Jun 30, 2026
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
M
Electrical 93 5.0 No Injector Pulse
  • machinermac
  • Jul 26, 2026
Fox 5.0 Mustang Tech Aug 1, 2026
Willybill32
