Got a P0442 Evap code. I did a visual check and found a hose that was half pulled out, so I pushed that back in. But when I went to the passenger side to check the filler tube I noticed that under the cover seemed to be rust. When I touched the rust it was damp and smelled of gas.
Obviously this isn't good and should be replaced. My question is what are the steps to remove and install?
Looks like you remove the bolt holding the tube by the tank and the bolts holding it to the body. Then it looks like it just slides out. I've read it might be better to replace the gasket where the tube goes into the tank as well.
