Fuel Tank
  • Thread starter Thread starter Shaolin Crane
  • Start date Start date May 2, 2010
Shaolin Crane
Banned
Oct 6, 2008
2,627
Kommiefornia
May 2, 2010
  • May 2, 2010
OK well my car ran dry running in the canyons because my fuel gauge doesnt work, when i fill it up it the gauge needle goes up so far the needle disappears, then the low fuel light comes on around half a tank and then its basically a guessing game till it goes dry, im assuming the sender is bad anyone got any insight for me?
T
TheUser
1,859
Springfield, MO
May 2, 2010
  • May 2, 2010
Not sure about the sender, but I generally figure out how many miles I can get out of a tank and use that as a rough estimate. I don't even usually use my gas gauges as much, I just watch my trip meter...it doesn't lie (as long as I reset it when I fill up & I get fairly consistent mpg).
Obviously mpg x gallons in your tank = miles you can drive.
I believe our tanks are 14.7...I'd probably figure it at 14 so you're a little on the low side and don't overdo it.
Shaolin Crane
Banned
Oct 6, 2008
2,627
Kommiefornia
May 2, 2010
  • May 2, 2010
thats what ive been doing, it wasnt a thread about how to get around fixing it, it was a thread about how to fix it
Liv2roc
42
  • May 2, 2010
I just changed my fuel tank sender unit. got it from ebay from a mustang parts store for about $75. mine was doing the same as yours and it works great now. its not that hard to change just run it low on gas and drop to tank took about 30 mins to change.
9
92foxstang
  • May 2, 2010
It could be the sending unit or also the anti slosh board (gas gauge amplifier) on the backside of the cluster here's an article on faulty Mustang gas gauge tips and what to look for.
1987LXragtop
837
Just outside Philly PA
May 3, 2010
  • May 3, 2010
mine does the same thing then it starts working again right around a 1/4 tank. Fill it up and the needle shoots all the way again.
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
F
Difference between 83-86 EFI and 87-97 gas tanks?
  • ForeverDrivin
  • Mar 30, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 30, 2026
ForeverDrivin
F
H
Fuel starvation issues, 91 EFI to carb swap. Car dying after 1-3 gallons used. EFI tank, electric fuel pump, bypass regulator. Dual fed carb
  • hassler
  • Oct 11, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 12, 2025
nickyb
Electrical Issues with my 2006 mustang gt
  • VerneVdV
  • May 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech May 22, 2026
VerneVdV
68 fuel gauge maxes out at half
  • connella08
  • Sep 5, 2025
Classic Mustang Specific Tech Sep 8, 2025
connella08
