Fuel
I just installed a BBK adjustable fuel pressure regulator and the liquid guage. I cannot not get this thing to read above 30. When at idle it sits on 30 then when i give it throttle it jumps down to just above 20. Anywho have a quick solution to this?
Well that isnt right. When you adjust the set screw it at no time changes the reading on the gauge. Maybe there is some trash in the reg from changing it?? I dont remember how I installed mine so Im out of options. Where is the pressure gauge installed?? What was the reading with the vac line plugged and giving it throttle like before??
It was a clean intall. I made sure the old O-ring wasnt down in the the hole the i wiped it clean of any dirt. I have the guage on the fuel line, coming off the valve. When the vacuum line is hooked up the pressure drops. But when it's capped off it stays at 30.
with vac connected at idle you should see bettween 30-32.as soon as you pull the vac off the pressure gauge should jump up.you should see between 37-39.if not adjust accordingly, if the pressure still doesnt reach a point where your comfortable then maybe its time to upgrade that fuel pump. good luck
