Aw man that was great!
Q: Say, like many guys, my crank has a slight bend to it- will this BJ work with a bent crank? I don't want to drop my belt at an inopportune moment! Also, I don't have access to any stripper- the wife won't let me keep any on hand- is it possible to enjoy a dirty BJ just as it comes? My standards are admittedly low, and pretty much any BJ will probably be fine by me. Any tips on how to get one of those off? Jun-09-09
A: The BJ will not be affected by a bent crank. You may wat to have your crank checked out by the machine shop do make sure it can be used. A dirty BJ is still a good BJ, but the grime may nick your belts and nicks are bad. The BJ is currently removed from the crank. If you need to get the crank off of the BJ later I recommend long smooth motions rather than quick jerky ones. If you use jerky motions the BJ may get the crank off too quickly and you may get hit in the face. I hope this helps, Jason
