Ok Its time to play Americas Favorite Game "Whats that Noise?" Im your Host BSapphire95GT, today we have a prime example...1995 gt 5.0 with bbk cai, shorty headers, o/r x pipe, dumped macs, aluminum driveshaft 5 speed transmission that makes a humming noise only during idling, and it goes away during higher rpms, happens while under load as well. as a side hint the idle climbs up to about 1.5k to 2k rpms and holds constant there...when driving if you put it in second gear and let off the car, it will climb in speed until you are eventually cruising at 2k.
attached is soundclip
http://www.youtube.com/watch?v=ZxHDVcDpSuk
on a sidenote...went over every single vacuum hose and wiggled it, sprayed it with soapy water, etc to determine if there was a leak, and none were found. Also when unplugging the maf the car does nothing, same with the IAC
